This is the plane that you flew John, changed the pushs rod to the new hole and it flys a lot better. Could not get the 20fp to start, it was a steel liner, and thought it was abn and did not run the oil precentage I should have.. So I put on the 25la so much more power, but it sounds like something is going to fall off.
