  • June 19, 2025, 08:47:11 AM
Author Topic: LA 25  (Read 2247 times)
Offline Steve Agrella
    • Steve Agrella Photography
LA 25
« on: July 31, 2011, 07:06:26 PM »
i just picked up a LA 25 on flea bay, I stole it for $45 brand new in the box ;D
Anyway I purchased a FP25 needle valve assy and venturi, I want to remove the remote needle assy stock plastic back , what back should I use.
Re: LA 25
« Reply #1 on: July 31, 2011, 08:08:29 PM »
If you can find a backplate for a .20/.25 FP, or TT .25GP, they will work. The trick is finding one. The easy alternative is buying a new CNC'd barstock backplate from Curtis Shipp, a member here on Stunthanger. Look under "Members".  About $12 plus postage. Curtis' address is:  m14m21(at)bellsouth(dot)net
While you're at it, replace the screws with socket heads from the local R/C car store. The head screws are 3mm x .5mm, but the backplate screws are 2.5mm x .6mm. Take samples for lengths, 'cause I don't remember.  I also like to replace the metric hex 1/4-28 prop nut with one that has an SAE hex...a Gr.8 from the local hardware store. H^^ Steve
« Last Edit: July 31, 2011, 08:35:54 PM by Steve Helmick »
Re: LA 25
« Reply #2 on: July 31, 2011, 09:33:12 PM »
Thanks Steve
Offline Luiz Ribeiro
    • Ribeiro's Home Page
Re: LA 25
« Reply #3 on: August 01, 2011, 06:18:38 AM »
Recently I bought from Tower Hobbies, for an O.S .25 LA, the back plate of TT GP .25 and the socket head screws for it, the socket head screws are made for RC cars. The manufacturer's numbers of those items in Tower Hobbies are:
ASCG2917      Associated Screw Set AE .15 12 (4 of 2.6X12mm; 8 of 2.6X7mm)
ASCC9454      Associated Socket Head Cap Screws M3X12mm (12)
TTRG8023      Thunder Tiger Back Plate GP-25
The original screws from O.S. for use in the back plate are 2.6X8mm, but you can use the 2.6X7mm from Associated, because the aluminum back plate of TT is 1 mm less thick than the original plastic of O.S. The originals O.S. for head are 3X12mm.
Of course, this way you will be paying for and getting a lot more screws (3X more) than you really need.
Luiz
« Last Edit: August 01, 2011, 07:23:49 AM by Luiz Ribeiro »
Re: LA 25
« Reply #4 on: August 01, 2011, 09:46:04 AM »
Thanks Luiz, I just ordered these from Tower, the TT aluminum back is only $5 what a deal
Re: LA 25
« Reply #5 on: August 01, 2011, 01:20:17 PM »
Optionally, for head, you can buy from Tower:
LXSAU5  Axial Cap Head M3X12mm black oxide (10)
Good  Luck.            Luiz
Offline Neil Campbell
Re: LA 25
« Reply #6 on: November 13, 2011, 06:40:00 PM »
I too just recently purchased a LA 25,, I have a os needle valve assembly and a thunder tiger back plate......Question is Do I need a gasket for the metal back plate?  the os with the plastic does not have a gasket.    which one from thunder tiger would I need
Neil C Campbell
Re: LA 25
« Reply #7 on: November 14, 2011, 08:40:13 PM »
Hi Neil,
Several answers on your other thread.  I use automotive gasket maker (in the tube).  20 years or more now and no problems.
Big Bear
Offline Russell Shaffer
Re: LA 25
« Reply #8 on: November 16, 2011, 08:50:06 AM »
If you use gasket goop, be sure to read the label.  Old style black Permatex cleans up with alcohol.  Found this out the hard way.
Russell Shaffer
Klamath Falls, Oregon
Offline Chad Hill
Re: LA 25
« Reply #9 on: November 16, 2011, 08:26:02 PM »
RSM makes a round backplate gasket for the LA25 (no dog ears). They also make delrin verturis for them.
