  • June 24, 2025, 03:02:54 PM
Author Topic: Uniflow Clunk Tank Engineering  (Read 1381 times)
« on: September 22, 2010, 07:06:34 PM »
If you make a old-style metal uniflow tank, then the amount of head in the tank is whatever the head is from the uniflow orifice to the needle valve.  To change the amount of head between upright and inverted, you have to move the tank up and down.
So far so good.
But I see two ways to make a uniflow clunk tank:  In one, you use a fixed-position rigid tube.  Then moving the orifice of the tube up and down (by twisting it from outside the tank) will change the head of the tank between upright and inverted, without having to move the whole tank up and down.  In the other, you attach the uniflow orifice to the clunk.  Then -- barring insufficiently flexible tubing -- there isn't anything you can do to change the head of the tank relative to the needle valve.  In fact, because of the flexible tubing this happens all the time, and automagically.
I gather from so many folks that advocate a clunk with uniflow in part because "you can move the uniflow up and down to tune the tank" that they're talking about a uniflow with a rigid tube.
'zat right?  Or am I confused again?
Offline Allan Perret
  • Proverbs
Re: Uniflow Clunk Tank Engineering
« Reply #1 on: September 22, 2010, 07:37:13 PM »
There is no orifice in the uniflow line / tube.   You described 2 ways to make a uniflow tank,  both will work.  So I am not clear on what you are confused about.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #2 on: September 22, 2010, 09:22:53 PM »
A rigid uniflow line, whose interior end can be moved but stays permanently there thru-out the flight, versus a flexible uniflow line tied to the (also flexible) pickup line, so it can't be "located" in a permanent position,  therefore can't be adjusted.  Right?
I've used both and can't tell a lot of difference.
--Ray
AMA902472
Offline Greg L Bahrman
« Reply #3 on: September 22, 2010, 09:24:13 PM »
Yes Tim and Ray, you got it. I use the uniflow attached to the pick up tube, both are flexable so they travel together and I move the tank up and down to get the same engine run upright and inverted........BUT........you can leave the tank stationary and move the uniflow tube up and down in the tank if it's a brass tube etc.
Greg Bahrman, AMA 312522
Simi Valley, Ca.
« Reply #4 on: September 22, 2010, 10:16:55 PM »
Orifice = opening = end of tube.
I wanted to know if one was better than the other.
  • Proverbs
« Reply #5 on: September 23, 2010, 06:13:10 AM »
Orifice =  restriction
I like the rigid plastic tube for uniflow, seperate from the engine feed clunk.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #6 on: September 23, 2010, 10:15:01 AM »
Not to argue or anything, but according to the dictionary:
"Definition of ORIFICE
: an opening (as a vent, mouth, or hole) through which something may pass "
No mention of restriction.  See for yourself: http://www.merriam-webster.com/dictionary/orifice
(and yes, it was probably a poor choice of wording on my part).
Thanks.
« Reply #7 on: September 23, 2010, 01:29:07 PM »
As I said previously I use the uniflow attached to the pick up tube, both are flexable so they travel together and I move the tank up and down to get the same engine run upright and inverted. I prefer to have them travel together so that the uniflow remains submerged in the fuel until the tank is almost empty at which time the engine run changes as a warning that you are close to empty. (don't do anything foolish) Ha Ha
Simi Valley, Ca.
