  • June 20, 2025, 04:18:31 PM
Author Topic: S T 60 Gasket set's  (Read 1039 times)
Offline Bootlegger
S T 60 Gasket set's
« on: May 24, 2011, 09:55:59 AM »
 y1   Guy's I am looking for some S T 60 Gasket set's. Any help locating same will be appreciated..   Thanks, Gil
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Martin Quartim
    • StuntHobby
Re: S T 60 Gasket set's
« Reply #1 on: May 24, 2011, 03:59:07 PM »
RSM has laser cut back plate gaskets for ST60 as well for other engines.
Martin
Offline Bootlegger
« Reply #2 on: May 27, 2011, 05:41:11 PM »
 H^^   Thanks Martin, I am looking for a full set. Thanks again... :!
Gil Causey
AMA# 6964
« Reply #3 on: May 31, 2011, 02:28:11 PM »
Hi Gil,
Contact Eric, he cuts more gaskets than he has listed and will "custom" cut.  I feel pretty sure he can cut the head gaskets too.  Back plate and head gaskets are all that's needed, right?
