  • July 09, 2025, 05:17:56 AM
Author Topic: K&B .35 Stunt ?  (Read 1801 times)
Offline Rob Killick
K&B .35 Stunt ?
« on: October 02, 2007, 07:58:23 PM »
Hi ,
A friend of mine has a K&B .35 Stunt and was asking me if it was a good engine ?
It looks like it's in good shape , but I've never , ever had a K&B product before .
Any opinions ?
Rob Killick , MAAC 33300
Offline Manuel Cortes
Re: K&B .35 Stunt ?
« Reply #1 on: October 03, 2007, 12:32:12 AM »
Hi all.
It´s the green head or the Stalllion?
Diferent engines.
Regards.
Manuel.
Offline Rob Killick
Re: K&B .35 Stunt ?
« Reply #2 on: October 03, 2007, 05:25:47 AM »
I'm guessing it's the Stallion (long prop driver).
All over natural aluminum (polished).
No dicernable markings that say "Stallion"
Spoked rear cover with allowance for pressure port.
Thanks for help  y1
Re: K&B .35 Stunt ?
« Reply #3 on: October 03, 2007, 05:34:07 AM »
Hi Rob:
In the early 1960's K&B built a 35 in the same generic case as the 40.  That is the exterior was all aluminum, bolt-on front case, it was possible to reverse the center section of the block to reverse the exhaust.  Venturi was a large trumpet shape with (I hink) an insert to sleeve it down for suction fuel feed.  I believe it said "Torpedo" on the case on the side opposite from the exhaust.  Not sure but I think it was also available in plain bearing ro ball bearing.
Does that description sound like your friend's engine?  Any way to post a pix?
Re: K&B .35 Stunt ?
« Reply #4 on: October 03, 2007, 10:42:33 AM »
Hi ,
Any opinions ?
Hi Rob
It would be good to see a picture of the engine, It maybe a Stallion 35, I had several of them and was not impressed by them as a stunt engine, they as more of a sport engine or maybe a slow combat motor, I used a couple of them on slow combat planes back in the 70s
Re: K&B .35 Stunt ?
« Reply #5 on: October 03, 2007, 03:56:50 PM »
The Stallion 35 has a shiny aluminum case and steel fins(part of the cylinder).  The Series75 35 also has a shiny case, but is built with a bolt on, plain bearing front end and a modified Torp 40 main crank case.  They also built a double ball-bearing version of the Torp series 61 and 64, with a separate front end and a matte finished case.  That was more of a racing/combat motor.
If the front end bolts on it is not a Stallion, which was a pretty good sport engine by the way.  If the front end bolts on it can be either the plain bearing Series 75 or an older Torpedo series 61 or 64
Offline Rob Killick
Re: K&B .35 Stunt ?
« Reply #6 on: October 03, 2007, 05:40:28 PM »
Ok ,
My pal set me the photos you asked for ...
Hope this helps ?
Rob
Offline BillLee
Re: K&B .35 Stunt ?
« Reply #7 on: October 04, 2007, 08:44:58 AM »
That's a Series 75. Plain bearing. Will likely need a venturi restrictor to run on suction.
Bill Lee
Bill Lee
AMA 20018
Re: K&B .35 Stunt ?
« Reply #8 on: October 04, 2007, 11:04:38 AM »
IMHO, they make a better racing engine than stunt engine.
Offline Rob Killick
Re: K&B .35 Stunt ?
« Reply #9 on: October 04, 2007, 06:13:12 PM »
Hi ,
Thanks fellas .
We really appreciate all the help ,
Rob
Offline Rob Killick
Re: K&B .35 Stunt ?
« Reply #10 on: October 05, 2007, 12:28:45 PM »
Hi ,
Just an addendum ...
This motor has been stripped for cleaning and is in great shape .
It also has a Dyke's piston ring .
Rob
