  • June 21, 2025, 02:40:32 AM
Author Topic: FP 25 Venturi  (Read 839 times)
Offline Robert Zambelli
FP 25 Venturi
« on: April 04, 2012, 05:33:42 PM »
I just acquired an FP 25 without a carb.
I will make a venturi but I'm not sure of the inside diameter.
The spray bar is .133 inch diameter.
Any suggestions for the venturi size?
Offline Geoff Goodworth
Re: FP 25 Venturi
« Reply #1 on: April 04, 2012, 05:50:49 PM »
Despite what Tower says on their web site, every FP 20/25 venturi I've bought from them measures 6.5mm ID.
Re: FP 25 Venturi
« Reply #2 on: April 05, 2012, 02:03:13 AM »
   And that is .256". That's perfect for the 20 and marginally too large for the 25, as long as you don't bog it down with excess prop diameter.
Re: FP 25 Venturi
« Reply #3 on: April 05, 2012, 05:09:01 AM »
Brett, can you suggest a reason why the 6.5mm venturi is right for the FP 20 but marginally too big for the 25 which is 20% larger displacement?
Also, can you suggest an ideal ID for the FP 25?
Re: FP 25 Venturi
« Reply #4 on: April 05, 2012, 08:47:39 AM »
  See the other thread for the full answer.  But who ever said there was a direct relationship between the displacement and the venturi size?
   The correct (as defined as WC-winning) venturi for a PA75 has less choke area than the 20FP, 40VF, PA61, or RO-Jett 61. I am currently running a #5 AWG venturi with a spigot in the RO-Jett and David ran something like a #13 with a spigot to win the WC - WAY less choke area.
  To first approximation, for a given airplane,  you have to suck in the same amount of air regardless of the displacement. A bigger engine can suck that amount of air through a smaller hole.
