  • June 24, 2025, 10:28:06 PM
Author Topic: OS .10 FSR Venturi  (Read 1178 times)
Offline Gary Mondry
OS .10 FSR Venturi
« on: August 28, 2010, 08:51:36 PM »
What venturi size would be a good starting place for an OS .10 FSR conversion?  I'm scratch building a Flying Clown which I plan to power with it.  I've got the venturi and NVA for a .15FP and they are a fine fit in the .10 case.  Venturi ID measures about .230.  The NVA is necked down from .136 for fit in the case to .125 through the venturi bore.  Will this be too large for the .10 FSR?  As good a place to start as any?  How about props?  I was thinking APC 7x3 to start.
Gary
AMA 10663
Re: OS .10 FSR Venturi
« Reply #1 on: August 28, 2010, 09:32:26 PM »
I know nuttink!
(check this thread: http://stunthanger.com/smf/index.php?topic=6285.0)
Offline Marvin Denny
« Reply #2 on: August 29, 2010, 09:24:35 AM »
  Gary,  If yopu want, bring the engine by and we can make a venturi on the lathe.
  Bigiron
marvin Denny  AMA  499
Offline Gary Mondry
« Reply #3 on: August 29, 2010, 08:05:55 PM »
Thanks, Marvin.  If I figure out that I need something different than what I have, I'll get with you.
Gary
AMA 10663
