  • June 14, 2025, 07:04:23 AM
Author Topic: Evo 36 specs....  (Read 1040 times)
Offline Tim Redelman
Evo 36 specs....
« on: March 31, 2016, 10:09:27 AM »
Thought I'd post this here, Day late and a dollar short but I figure maybe in the future somebody might want to use it. D>K
Type: 2-stroke
Displacement: .36 cu in (5.71cc)
Bore: .81 in
Stroke: .70 in
Cylinders: Single
Engine (Only) Weight: 9.30 oz
Muffler Weight: Tongue muffler 0.5 oz (14 g); cast muffler 2.118 oz
Crankshaft Threads: 1/4 x 28 in
Prop Range: 9x5 - 12x5
RPM Range: 9,300 to 17,000
Fuel: 5% - 15% Nitro
Mounting Dimensions: 38mm x 15mm
Muffler Type: Tongue (machined) - Std expansion-type - cast
Cylinder Type: ABC
Carb Type: venturi sizes - .225 in (5.7mm), .235 in (6.0mm), .275 in (7.0mm)
Experience Level: Beginner
Tim
