  • June 22, 2025, 06:01:27 AM
Author Topic: Which plug, Fox RC or Enya No. 3  (Read 1580 times)
Offline frank mccune
« on: May 27, 2015, 11:19:33 AM »
       That is the only choice that I have at the LHS. Which would be better for Stunt?
        Tia.
        Frank
Re: Which plug, Fox RC or Enya No. 3
« Reply #1 on: May 27, 2015, 11:29:08 AM »
The Enya by far but you can get good Glow Devils from McDaniel R/C Sonic Tronics on the web in your mail box in 3-4 days.  My experience with the Fox is that due to a finer platinum element they glow very bright but also are damaged and go out very quickly.  I have a 20 year old Enya in my box I ran for years and still use it on the test stand sometimes.
« Last Edit: May 27, 2015, 12:28:18 PM by Dave_Trible »
Offline Phil Bare
« Reply #2 on: May 27, 2015, 03:13:26 PM »
Hands down, the Fox RC is the best choice.
Phil Bare
« Reply #3 on: May 27, 2015, 08:36:44 PM »
        Tia.
        Frank
Glow Plugs  can also be  a  major cause of trouble, and poor runs.  When you first crank the plane, notice if it goes rich and sags slightly when the battery is removed; if so, the plug is normally too cold.  This is  critical to getting a proper Stunt run.
Most plugs are designed to provide a  colder range than we want in C\L aerobatic engines , and you should try to get the right range for the motor.  Many days of testing and much time and expense buying almost every plug on the market has yielded these results ;Thunder Bolt R\C long, T Bolt #3 , T Bolt 4 stroke, Glo Devil RC #300 long,  Enya 3 & 4, Fireball RC long, the Hobby Shack RC long, SIC RC long  a few of the OS hotter plugs and some of the FOX long and  Miracle plugs are best plugs for our use.  In almost all instances, use a long plus, as they will be substantially hotter than the shorts, plus they are deeper in the combustion chamber and this tends to keep things hotter and keeps  the plug elements cleaner.
A lot of times the plug problems show up as rich inside maneuvers and leaner outsides; this happens because gravity and centrifugal force ,forces the oil-fuel charge down on the element on insides, thus cooling the coil and pulls it away on the outside maneuvers, letting it naturally go leaner.  I have seen this problem instantly cured by simply changing plugs. Please  do not be  afraid  to put in a  new  glo plug , or try different types of plugs .
 All of this assumes you have your tank height perfect (you did adjust your tank height, didn’t you), you’re right side up and inverted lap times are the same.  This is important; don’t skip this step. If your  using a  profile sometimes you will need  to have the tank center higher than the engine center. The 3 \16 to 3 \8 range will do for most fox 35s . Others will run on center line ,or just off of it. Another case of run problems are tanks or fuel delivery systems, which includes the tank, fuel tubing ,fuel filter, and anything else connected to the fuel system. When these problems arise in most cases, the engine changes speeds in flight, either faster or slower , and is generally inconsistent in the needle setting. This is almost always blamed as an “engine problem” when in fact it almost always turns out to be a tank problem, or fuel delivery system problem. I find most every time I see this , it is one component of the fuel system that is at fault. Either a hole in the fuel tubing, junk in the filter, a hole in the tank, a tank with an internal crack in the pick up or feed line . The next most common problem of this is water in the fuel. Water will give a very inconsistent needle setting, and will change at random back and forth from lean to rich. There are a few other things that cause problems with fuel delivery, muffler or pipe pressure will, most times magnify any little leak or problem you have and make things much worse than they were. A few other causes are an engine with a leaking backplate gasket, or an improperly cooled engine. A basic rule of thumb is to have a good intake area, with double the size of the exhaust area. Make sure you model (if fully cowled) has the air blowing all the way across and past the engine before the air flow exits the cowling.  If your plane goes lean in maneuvers and comes back to a four-cycle slowly, it can be running too hot, you most likely need more oil, or less back pressure from the muffler.  I have seen a lot of fuel with water in it (methanol attracts water) and this will cause erratic runs and needle settings.  Always use fresh fuel and don’t be afraid to try another fuel if you think this is the problem.
« Reply #4 on: May 28, 2015, 09:02:15 PM »
      Of those two, the Enya, by far. The A good Fox plug works fine, but the chances of getting a good one seem to be about 20%.
    Note that any plug can be ordered over the internet. Most of the R/C or 4-cycle plugs work fine and some engines like different plugs. The only one to NEVER get is any Rossi plug, they are notorious for the "quite like you flipped a switch" problem.
     Thunderbolt are the ones I use. The Thunnderbolt 4-cycle plug we use seems to be discontinued but there is a close equivalent, and the RC plug works fine, too. They used to be a good bargain but that was when they were 79 cents. When (if) I run out of my current stash, I will probably switch to something else.
