Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 20, 2025, 12:24:26 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
os max sr .40
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: os max sr .40 (Read 1410 times)
mark eisenhut
Trade Count:
0
Lieutenant
os max sr .40
on:
November 28, 2006, 10:26:22 AM »
i just found one of these sr .40 os max are they any good and what are the worth Ive never seen one before i need your info before i make a mistake the motor look new no mounting marks good compresion and i think it's ball bearing. any help would be welcome and can a fp or la venturi be used?
thank you
mark eisenhut
Logged
mark eisenhut
Manuel Cortes
Trade Count:
0
Commander
Re: os max sr .40
Reply #1 on:
November 28, 2006, 10:31:15 AM »
Hello, Mark:
If itīs the FSR, I run one during a season, lots of power, I tame retiming the sleeve and fiting a .275 venturi, but it did very well with a Claus Maikis Indigo (beautiful plane, by the way),
Hope it helps.
Regards.
Manuel.
Logged
mark eisenhut
Trade Count:
0
Lieutenant
Re: os max sr .40
Reply #2 on:
December 04, 2006, 03:11:20 PM »
Manuel,
where did you get a venturi .275 for it. i also need a muffler any help is welcomed
thanks
mark
Logged
mark eisenhut
Ward Van Duzer
2015
Trade Count:
0
Admiral
Re: os max sr .40
Reply #3 on:
December 06, 2006, 02:00:08 PM »
Mark,
While there are probably better engines out there for stunt, everything you need can be had from our moderator, Randy Smith.
Logged
They are easier to handle than dumb mistakes! Ward-O AMA 6022
mark eisenhut
Trade Count:
0
Lieutenant
Re: os max sr .40
Reply #4 on:
December 06, 2006, 04:27:30 PM »
thanks for the info . found everthing at tower hobbies.
thanks again
mark eisenhut
Logged
mark eisenhut
Manuel Cortes
Trade Count:
0
Commander
Re: os max sr .40
Reply #5 on:
December 07, 2006, 03:53:43 AM »
Sorry, I was out.
My venturi was suplied by Tom Dixon, is the same as OS 46SF and OS 40 SF.
Regards.
Manuel
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
os max sr .40
