  • June 17, 2025, 10:07:34 AM
Author Topic: High humidity - impact on engine run?  (Read 3578 times)
Online Dennis Toth
« on: April 05, 2014, 11:56:42 AM »
Guys,
Got to the field today, it was a great day, light wind, slight clouds but the humidity was a bit higher. The engine run seemed to be a bit leaner than in the cooler weather.
Can anyone give some insight on how the humidity affects the engine run (4-2-4, 5% nitro, 27% 50/50, Fox 35 on 9x6 old Top Flite) and options to adjust?
Best,        DennisT
Offline Gordon Tarbell
Re: High humidity - impact on engine run?
« Reply #1 on: April 06, 2014, 06:17:19 AM »
On the simple side, the higher the humidity, the higher the density altitude. Higher density altitude the less oxygen to make power. Just add more nitro% to compensate.
Gordon Tarbell AMA 15019
« Reply #2 on: April 06, 2014, 11:03:35 AM »
Guys,
Best,        DennisT
   Less power. More nitro.
Online Dennis Toth
« Reply #3 on: April 06, 2014, 12:09:47 PM »
That's kinda what I thought.
Best,   DennisT
Offline Timothy Payne
  • Mr Payne
  • Classic Racer
« Reply #4 on: April 25, 2014, 01:55:16 AM »
It's all to do with Relative Air Density (RAD).
Basically in warmer weather air pressure is lower with less oxygen in the air. 2-Strokes generally prefer cold, drizzly conditions (ask any classic 2-stroke motorcycle racer!).
This is down to a higher RAD, with more oxygen present. In these conditions your engine may run a tad rich so just screw the needle valve in 2-3 clicks. Vice versa in warmer conditions; make it slightly richer at the needle.
You shouldn't need more than 15% nitro for a standard setup.
See how you go on with this, it might also be worth going for a colder plug (no5-8 range) in warmer weather also.
Tim
Tags: engine  fox 35  setup
