  • June 16, 2025, 03:10:22 PM
Author Topic: It's a .25...I think.  (Read 2290 times)
« on: January 02, 2014, 10:05:32 PM »
 I've just acquired this Fox engine and I'm not 100% sure what it is. I'm thinkin' it's a .25. I've got a couple of the "regular" .25's but isn't there another .25 that they did like this with the bolt on cylinder? Can anyone here give any confirmation on my thoughts? ;D
Offline Russell Shaffer
Re: It's a .25...I think.
« Reply #1 on: January 02, 2014, 10:20:56 PM »
If you remove the head (carefully, the cylinder will want to come off also) and measure the bore and stroke you can calculate the displacement.  I have a matched pair of 19's that look just like yours.
Russell Shaffer
Klamath Falls, Oregon
« Reply #2 on: January 02, 2014, 10:59:33 PM »
 Hmm, I never knew of a .19 in this style. I knew I could take it apart and measure it up, but I was hoping to take the easy road.
 Thanks Russell. H^^
Offline dennis lipsett
« Reply #3 on: January 03, 2014, 06:31:43 AM »
 Thanks Russell. H^^
It is easy to tell what it is.
Fox made that as a 19 and then discontinued it and made a 25. The 25 has the displacement stamped on the lug the 19 is unmarked. These are actually very good engines but are really favored for speed limit combat rather than stunt. Both of them are excellent running engines.
Dennis
« Reply #4 on: January 03, 2014, 10:10:09 PM »
 Dennis, do you mean the engine mounting lug?
« Reply #5 on: January 04, 2014, 04:47:13 AM »
Yes the upper face of the left mounting lug. pictures of the 19&25 showing the 25 marked
« Reply #6 on: January 04, 2014, 08:33:57 PM »
 I just got a chance to look at it again. The engine I have is unmarked, so it must be a .19. It's in excellent shape but I don't really have any use for it. At least now I know what it is though.
 Thanks for the help guys! ;D
Offline Timothy Payne
  • Mr Payne
  • Classic Racer
« Reply #7 on: February 26, 2014, 02:07:19 AM »
It's a Fox 19. Stick it in a 1/2 A Combat running 10-15% nitro 23% castor fuel (unsilenced) and you should get a good few years flying out of it before it needs anything major doing to it (providing you tighten the mounting bolts down enough; unlike me with my 29X on it's maiden flight! - Engine parted company halfway through testing, carried on running too! (Fortunately no one was hurt and the engine was unscathed:-).
Currently looking for a new club to fly with!
Tim
« Reply #8 on: February 28, 2014, 12:04:31 AM »
Hold on a second guys. I have a few of those NIB in .19 and .25 displacement and NONE of them are marked anywhere. So it's possible the engine here is in fact a .25.
Offline Phil Bare
« Reply #9 on: February 28, 2014, 08:46:54 AM »
If anyone has a CL .25 that they will part with. Let me know.
Regards, Phil
« Reply #10 on: February 28, 2014, 08:49:47 AM »
Regards, Phil
Some really like the 25 in speed limit combat. incidentally all of the 25's that I have are marked but then again I've had mine for a long time time they may have ceased marking them as the 19 is long gone
Dennis
  • Mr Payne
  • Classic Racer
« Reply #11 on: April 25, 2014, 08:27:23 AM »
If it's a 25 the bore + stroke will be 0.738" * 0.600" (0.700 if it's a 29).
Hope this helps,
Tim
