Bob,
I agree that you should use short plugs as recommended by Fox.
Both of mine have long plugs installed by previous owners, and right or wrong they run fine that way.
I also rechecked the other long plugs I have on hand (a mix of Fireball, Fox, McCoy, Merlin, and who knows what else) and none of them contact the piston. Then I removed the plug washers, and checked again - still no contact!
So stick with short plugs to be absolutely safe.
Only use long plugs in a pinch, and only after checking clearance without the plug washer first. Then install a new plug washer, and check again.
