  • July 04, 2025, 12:42:02 PM
Author Topic: Inverted engine starting  (Read 1880 times)
Offline Vincent Corwell
« on: March 13, 2009, 04:04:35 PM »
Any tips for starting inverted engines ?
can it be done without priming , pre running,
burping etc , usually done with the engine
upright, difficult to hold without help
all so unnecessary with sidewinder or
upright engine installations.
I have built a large number of stunters
with side mount engines for this reason
no problems with those.
but the few I have with inverted engines
take a lot of extra trouble to start
any help ?
Vincent
Alan Hahn
Re: Inverted engine starting
« Reply #1 on: March 13, 2009, 06:52:11 PM »
Vincent,
The biggest issue with inverted engines is priming. I mounted a foam ear plug on a bamboo skewer so that i could plug it into the venturi. That being said, if you completely plug the venturi and flip the prop, you draw fuel all right, but since the venturi is plugged, there is no airflow to pull the fuel up into the engine. That's why I try not to plug it completely, but leave a small air leak to get some fuel sucked up.
So the bottom line is that is hard to flood an inverted engine---gravity is working against you,
But in the end, I got pretty good at starting my inverted Brodak 40. So it can be done without a lot of problems.
Offline Jim Oliver
« Reply #2 on: March 13, 2009, 08:19:09 PM »
My experience with inverted engines in CL is limited to the Brodak 40, ST 51 and PA 61.
The B40 floods very easily upright and can be flooded when choking inverted-----usually choking for two or three blades will be enough.
On the ST 51, I inverted the model and choked three or four blades, then set the model on the gear for starting.
With the PA 61 Rear Exhaust, I invert the model and choke 3 blades, then pull the prop thru about four blades, then set the model on the gear------last 25 or so flights have started with a single back flip.
I really don't like starting the engine with the model inverted and then having to turn the model over with the engine running; it's not too bad with .25/.35 size but larger models can be difficult to handle safely.
Forgot to add, I use a piece of pantyhose over the venturi as an air filter; the weave seems to trap a little fuel, the vapors of which may help starting...........
Cheers,
Jim
Jim Oliver
AMA 18475
« Reply #3 on: March 14, 2009, 01:44:39 AM »
Thanks Jim & Oliver
What I want to avoid is turning the plane over
while the engine is running, especially while
flying alone
Vincent
Offline Wayne J. Buran
« Reply #4 on: March 14, 2009, 05:18:11 AM »
Thanks Jim & Oliver
flying alone
Vincent
Vince, there may come a time when inverted is the only way, In which case it is most important that your partner understand completely the ritual of how it's done. Do it the same everytime and try to use the same partner. It gets much esier and safer.
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
USAF Veteran 35 TAC GP/ 6236 CSG, DonMuang RTAFB, Bangkok, Thailand 65-66 North Coast Controliners   "A fine is a tax for doing wrong. A tax is a fine for doing well!
« Reply #5 on: March 14, 2009, 06:39:57 AM »
I've solo started several inverted engines (G.51 & 2Star .60bb), with very good results. It happened that I had Bruline air filters installed, and my proceedure was to choke either until there was some fuel on the filter, flip it a few times, feel for the bump and whack it or use the "electric finger". If it's on the dry side, I'll hit the starter and put my pinky over the muffler outlet (when running muffler pressure). That can work wonderfully...and it's a pretty subtle boost of fuel mixture. If flying solo, I think the starter is a fine idea for safety. I'm currently using a Kavan with the attached Ni-Cad pack...works well, with a wrap of electron tape around the starter cup.  VD~ Steve
« Reply #6 on: March 14, 2009, 06:52:16 AM »
On most of the old motors, Foxes, McCoys, and OS, place a finger over the ventura while pulling the prop halfway through compression, then remove your finger and you will hear the fuel air suck up into the engine. Three chokes like this will generally get them going.
Offline Jim Oliver
« Reply #7 on: March 14, 2009, 08:11:44 AM »
As much as I dislike using electric starters, especially on engines without ball bearings, safety must trump tradition.......
So far, the electric starter has been needed only on the inverted ST 51.
Jim
Jim Oliver
AMA 18475
Offline Bootlegger
« Reply #8 on: March 14, 2009, 08:15:46 AM »
  Another method and I use it is to flip model on it's back, choke it, then flip to distribute the fuel, then back upright, hook up battery and start engine.  You will have to try variables of this method with each engine, but it works...
            Hope that this helps
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Brian Hampton
« Reply #9 on: March 14, 2009, 08:38:15 AM »
I always start mine inverted but there's a trick to it. The trick of course is getting the fuel to run uphill. I cover the intake with a finger, pull the prop through a couple of times until I know fuel is getting through the spray bar and sitting on my finger. Then give a fast flick but roll my finger slightly off the intake to leave a small gap so air can rush through and sweep the fuel up through the crankshaft port. As with any engine you need to learn how many of these primes it likes for an instant start. Most engines are fairly forgiving on a slight overprime but my Irvine 40RLS only needs about half a drop too much and it'll try to take my finger off :). The G51, VF's and Stalker are dead easy though.
« Reply #10 on: March 14, 2009, 10:08:09 AM »
With my Nobler I can only get a finger inside the cowl for about 1/4 revolution of the prop.  It can be done, but it's a pain, and not really exact and repeatable every time.  What I found works is to fill my syringe with 1/4 ounce more fuel then I need to complete the pattern.  Then I fill the tank all but that last 1/4 ounce, cap the overflow, and push about an 1/8 ounce into the tank.  This process pushes fuel through the line, and up to the spraybar, and the excess runs out the venturi.  I give the engine a few flips, and then push a bit more through and quickly flip the engine several more times.  Usually I can feel when the fuel flows into the engine.  I disconnect the syringe, hook up the battery, and it usually goes on the first flip.
« Reply #11 on: March 14, 2009, 05:36:51 PM »
any help ?
Vincent
   I find it easier to start them inverted than upright or sidewinder. It's all a matter of technique. For the first start of the day I "burp" the engine to clean out all the old oil and get it less gummy. Hold airplane inverted, no fuel in tank. I usually turn it until the intake is closed, and then dribble fuel in until the intake stack is full. Then flip it forwards a  few times, rotate the airplane around while rocking the prop to get the fuel into the cylinder, and to wash out the old oil. You can feel the engine loosen up. Last, hold it nose up and exhaust  down and rock it to get the excess fuel out. The engine should flip through with no problems - if it's locked, hold it exhaust down and rock some more to get out the excess. Then have the holder hold the airplane inverted , attach battery and back-bump until it starts and runs out the prime. Prime some more, do it again, prime again, start again, and then back-bump it a few more time to make sure the fuel is out of it. At this point the engine is warm, flushed completely, and mostly free of raw fuel.
   When it's time to fly, fuel the airplane, set it on its wheels, and pull the engine forward through compression 3-4 times, and then while flipping it forward, remove your finger. There's some timing to be done because you want to remove your finger in mid-flip. Continue flipping forwards a few more time and you will be able to hear and feel a little fuel sloshing around in the engine. This aerates the engine and gets the fuel/air mix in the engine just right. Then it's ready, attach the battery, and back-bump the engine and it will probably starts. You will have to experiment with how much choking you need to do on any particular engine, but most current engines will tolerate A LOT of choking and will start at just about any point short of being hydraulically locked up - as long as you don't try to start it by flipping forward! If you start with forward flipping it's much more critical about getting exactly the right conditions, and if it's slightly too rich it will kick back before you get to TDC and cut your finger, whack it, or something else bad. That's why you don't see many people flipping forward with current engines and props - they are just too dangerous to start that way.
    It takes a lot more time to write it down than it does to do it, and you will see virtually everyone at the Nationals doing the same thing.
    One caution - with almost any current high-quality motor, be prepared for it to start *at any point* that you have fuel present, battery or not. The piston/cylinder fits are so exceptional that they very frequently pop and start with no battery. My PA61 was notorious for that, even in 45 degree weather first time in the morning. And in the very hot weather at the 93 NATS, I gave up trying to choke the engine (stock 40VF)on the ground because it would start every single time. I would loosen it up before the flight, fuel it up, take it on the circle, and signal before any choking because it was going to start as soon as I touched the prop. I had that happen on very rare occasions on the ST46. But it's very much more common now than it used to be because the fits are so much better than they used to be. In particular, make sure your holder is holding on before *any* choking or aerating because it *will* start occasionally.
Offline Terry Bolin
  • Havin' the time of our lives!
« Reply #12 on: March 15, 2009, 07:48:23 AM »
I have had the best luck burbing them while the motor is right side up. I use a Cheap styro-foam cooler with cut outs for the fuse to hold the plane while warming it up. Cold temps, .... they just aren't happy. (We add lighter fluid to the venturi in very cold temps ) Then turn it up-right and fill the tank. My ST-51 will start well the rest of the day  with just a choke or two and then flip three or 4 times before adding the glow clip.
You'll find your combo!
