  • June 17, 2025, 08:18:49 AM
Author Topic: O S L A 46S engine  (Read 1087 times)
Offline Bootlegger
O S L A 46S engine
« on: August 09, 2019, 11:31:26 AM »
  What is the difference between the O S L A 46 S engine and the regular O S L A (R/C) engine, also how about the O S 702 muffler, is it a good muffler to run the engine in on?  Again thanks
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: O S L A 46S engine
« Reply #1 on: August 09, 2019, 12:05:21 PM »
  One has a carburetor, the other has a venturi, otherwise, the same.
« Reply #2 on: August 09, 2019, 12:28:42 PM »
The OS 46LA seems to be ideal for stunt, and much lower in cost than "custom for-purpose" stunt engines.
The stock OS mufflers are big and ugly, even though they work well.  I advise using a tube muffler made by Scott dinger (if you can get one).
