  • July 09, 2025, 07:26:54 PM
Author Topic: Inevitable Mistakes  (Read 1260 times)
Offline Leo Mehl
Inevitable Mistakes
« on: June 06, 2007, 05:12:41 PM »
As we grow older we tend to make mistakes and sometimes they become very frustrating. Ha two incedents happen this week to two of my friends. No. 1. One of my friends did a strega arf with a super Tigre 60 in it. The engine did not seem to run right on most of his early flights. On his last flight of the day we could not get te engine to start so we all had solutions. None of these seemed to work so we gave up for the day. WEhen he got home he took engine out of the plane and discovered yhat all the bacplate bolts were loose or completly out. No crankcase vacume. Case no 2. another case where plane is new and everything seemed to be OK. This plane ha a OSLA40 in it and was going to be run on pressere from the muffler. The engine would not hold a steady run when one of the guys noticed the toung muffler was loose. He tightened it down and the problem was solved. I think most of this could have been prevented by bench checkin everything before going to the field. I guess when we get older we think we have done good and don't think we have to check. Lesson No 1 after 60. HB~> HB~> HB~> HB~> mw~ mw~ Z@@ZZZ Z@@ZZZ
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Inevitable Mistakes
« Reply #1 on: June 06, 2007, 07:19:47 PM »
Age has nothing to do with it.. Not that this is aimed at anyone but if you have been hanging around flying fields. long enough you notice there are those that seem to never have any trouble and those that are always having some sort of issue  ;D
Offline Manuel Cortes
« Reply #2 on: June 07, 2007, 02:04:39 AM »
Hi all.
I flew ALL my 1994 Spanish Nats with my Merco 35 misfiring due to the same cause...... I discovered it back at home.
Lucky that even misfiring, the 32 Oz plane was hauled relatively OK......and obviously was this year excuse for my final position...HAHAHAHAHAHAH!!!!!!!!!
Regards.
Manuel.
Offline don Burke
« Reply #3 on: June 07, 2007, 09:52:37 AM »
Not only PA.  I had an engine "teched" after a racing NATS top three, head and backplate removed.  The next two times I tried to run it, it wouldn't start, switched engines both times.  Finally checked the head and back plate bolts, guess what!  DUUUHHHHHH!
don Burke AMA 843
Menifee, CA
« Reply #4 on: June 07, 2007, 10:23:22 AM »
That is so true!!! Even when I was young right to the present, some guys were always having problems and some cats just flew.  You hit the nail on the head with that one. #^
Offline Peter Anglberger
« Reply #5 on: June 07, 2007, 09:07:01 PM »
One of my club mates, Maris Dislers has good advice: heed the "5P's":
 or "Prior Preparation Prevents @#$% Poor Performance" I wasn't sure whether the 3rd word is too rude to print out in full, but I suspect not as people have been talking about 'wankers' on the forum.
Peter
« Reply #6 on: June 09, 2007, 06:14:25 PM »
"Prevents" is not a problem. "Wankers" are rotary engines, right? LL~  LL~ LL~ LL~ Steve
« Reply #7 on: June 09, 2007, 10:04:49 PM »
Actually I believe it all has to do with moon phases........ just like the tides.......
 S?P  LL~ LL~   HH%%  H^^
