  • June 24, 2025, 04:50:40 PM
Author Topic: rear bearing removal  (Read 1031 times)
Offline Fred Quedenfeld jr
« on: April 30, 2010, 11:53:34 AM »
SOOO you lightly heat up the case  grab you hot gloove give the case a real smart rap on your wooden work bench
and the rear bearing does not come out
What do you try next?
Fred Quedenfeld jr
Re: rear bearing removal
« Reply #1 on: April 30, 2010, 02:00:04 PM »
Fred Quedenfeld jr
Clean it up well, Put it in an iron skillet ,facing backplate area down, insert into a 450 degee oven and let the case expand, the bearing should drop to the skillett.
If it does not you may have too much rust, too much burned castor, or too much of both, In that case install in a crock pot full of 100% antifreeze, and cook for 8 hours to clean the area, then try again
Offline Allan Perret
  • Proverbs
« Reply #2 on: April 30, 2010, 02:35:24 PM »
What temperature do the crock pots get up to ?
Was wondering if the Frying type cookers which get to 350° would be too hot for antifreeze degunking procedure ??
Allan Perret
AMA 302406
Slidell, Louisiana
Online Paul Smith
« Reply #3 on: May 01, 2010, 07:01:11 AM »
Unless it's under a clamp-down pressure lid it only gets to the boiling point of the antifreeze, which I don't exactly know, but I think it's not much higher than water, 100 C.
Offline Noel Corney
« Reply #4 on: May 03, 2010, 11:35:19 PM »
Just remember not to cook in it after the antifreze.Noel.
« Reply #5 on: May 04, 2010, 09:33:27 PM »
I once had a Taipan 2.5 (last one, Rossi/Conquest clone) with a bad rear bearing that refused to come out. I turned a piece of soft (6061T6) aluminum rod to fit the bearing ID, drilled a 1/8" hole down the center. Then I split this plug about 3/4 of the length, screwed in a small sheet metal screw, (screw head inside the case bore) and with some heat and some tapping on the head of the screw, out she came. Turned out to be a nice runner, but not as fast as a Rossi or Conquest.  y1 Steve
Offline Pinecone
« Reply #6 on: May 05, 2010, 07:10:06 AM »
How hot and how long did you heat?
I use an IR thermometer to get the case up to about 240F and the a light tape and it comes out.
I don't like taking al alloys too hot, as it can cause changes in the alloy.
Terry Carraway
AMA 47402
« Reply #7 on: May 05, 2010, 06:02:05 PM »
Fred, try heating the case in the oven for half an hour at 250 deg. and then whack it.  If that doesn't work, Steve Helmick's idea should do the trick.
