Good job on the pictures, Gordon! You did all the resizing and compression yourself? Or was it the 13 year old kid down the street?
Nothing engraved on the case or head? Many tuners do that. GMA vibro-engraved "GMA" on the side of the head. I have a Big Jim ST .60, and it has "L" on one side of the bypass and "J" on the other (LJ for "Large Jim"), and LJ on the front side of the head. I have a few Tom Lay engines, and they have "T&L" engraved on one lug and a serial number on the other. I believe Randy engraves something on his reworks; dunno about others, but it's likely. I don't know who else might have done ST .60bb reworks, back in the day.
Regarding the holes in the liner and piston...lots of older engines had similar holes. I think McCoy .60's, and maybe OS MAX III's. But the holes were in the piston skirt, certainly not above the wristpin bosses. So, that looks maybe stock, or maybe not, to me. It should do a fair job of cooling the piston crown from underside, but as for power, probably not. I am pretty sure Perry Ports are not like that. I have an engine with PP's, and that is not even close to similar. I'll have to ponder which engine that would be, and then find it. With PP's, you can look in the exhaust and see some extra bypass sorta things. These on your .60, you wouldn't be able to see from the open exhaust stack.
