Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
---->Stunt News click here<----
June 19, 2025, 07:42:05 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Bushing a Prop
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Bushing a Prop (Read 2960 times)
Serge_Krauss
Trade Count:
0
Admiral
Bushing a Prop
on:
May 06, 2017, 10:34:00 AM »
I'm not sure this is the right section to ask, but...
What are you guys using to to reduce the diameter of a propeller hole, when it is too large for the engine's shaft diameter. Brass tubing? CF extrusion?... Thanks all!
SK
Logged
George Truett
2018 Supporter
Trade Count:
0
Commander
Re: Bushing a Prop
Reply #1 on:
May 06, 2017, 01:37:52 PM »
Jim Lee has 1/4" i.d. prop bushings in two different o.d.s, don't know if he offers any other sizes.
Logged
Brad LaPointe
24 supporter
Trade Count:
0
Commander
Re: Bushing a Prop
Reply #2 on:
May 06, 2017, 03:46:48 PM »
Duct tape .
Brad
Logged
Dave_Trible
24 supporter
Trade Count:
0
Admiral
Re: Bushing a Prop
Reply #3 on:
May 07, 2017, 12:58:35 PM »
Serge I've used the telescoping aluminum K&S tubing from the hardware store. May take two or three sizes to get you sleeved down. A drop of cyA keeps the sleeves together when changing props etc. Trying to fill the hole and re-drill can be pretty hard to get perfect without some pretty fancy jigging.
Logged
RandySmith
Administrator
Trade Count:
0
Admiral
Welcome to the Stunt Hanger.
Re: Bushing a Prop
Reply #4 on:
May 07, 2017, 01:50:36 PM »
best, easiest to use is either spinner bushings, or tubing, I just take aluminum tubing, roll a razor blade over it, and you can cut your own bushings in no time, different diameter tubes will make it possible to bush most any prop
Logged
Serge_Krauss
Trade Count:
0
Admiral
Re: Bushing a Prop
Reply #5 on:
May 08, 2017, 09:03:35 PM »
Thanks guys! I'm off tomorrow to replenish my stock of tubing.
SK
Logged
Trade Count:
0
Admiral
AMA78415
Re: Bushing a Prop
Reply #6 on:
May 17, 2017, 07:20:08 PM »
A short piece of fiberglass arrow shaft works to go from 1/4" to 5/16".
Logged
Target
C/L Addict
2019 supporter
Trade Count:
0
Admiral
Re: Bushing a Prop
Reply #7 on:
May 23, 2017, 11:16:07 PM »
How about some fuel line?
I've heard it used for 1/2A's, but as long as the prop stays on center as you get the nut tight, you should be good, especially if the thrust washer has a not too sloppy fit to the shaft.
Logged
Chris
AMA 5956
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Bushing a Prop
