  • June 17, 2025, 08:39:36 PM
Author Topic: T D 049-051  (Read 1255 times)
Offline Bootlegger
T D 049-051
« on: January 13, 2020, 09:56:50 AM »
   Folks I need info on removing the venturi removal from T D 049-051 Cox engine..All help is appreciated...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline George Truett
Re: T D 049-051
« Reply #1 on: January 13, 2020, 10:19:51 AM »
Re: T D 049-051
« Reply #2 on: January 13, 2020, 10:50:48 AM »
   The venturi itself just screws out, and it clamps the needle/metering block between the venturi and the plastic. To remove the plastic housing, you have to remove the thrust washer and unscrew the aluminum clamp. I used the aluminum clamp as a jack to push off the thrust washer.
Offline Fredvon4
  • Central Texas
Re: T D 049-051
« Reply #3 on: January 13, 2020, 12:33:07 PM »
heat is needed if plastic or aluminum venturi/carb housing must come off....it is keyed to a crankcase flat so it will not spin/ turn off....thin knife blade to pry straight off....exacto blade too brittle be careful....unless carb body is cracked or damaged leave it the hell alone!
I prefer the readily available plastic repair parts...I have 5 higher cost aftermarket aluminum on my TeeDees....heavier, leak prone, and usually twice price.....
Fred von Gortler IV
Re: T D 049-051
« Reply #4 on: January 13, 2020, 04:57:17 PM »
Yea. Plastic etc is usually brittler cold . Dont melt it though ! . A heat gun might assist the process . dont lever on the intake .
Online 944_Jim
Re: T D 049-051
« Reply #5 on: January 13, 2020, 05:42:29 PM »
Mr. Fred,
I wouldn't have expected that response to the aftermarket aluminum ones. I think you just talked me out if getting one or two for my Tee Dee .020s.
Thanks for the save!
Re: T D 049-051
« Reply #6 on: January 13, 2020, 10:16:52 PM »
Unfortunately, the plastic carb bodies are very fragile, so most of them get broken even under normal use. Even catching them with your finger when flipping tends to crack them.
Offline Fredvon4
  • Central Texas
Re: T D 049-051
« Reply #7 on: January 14, 2020, 08:50:58 AM »
Jim if your teedee 20s are "forever engines" mounted on a craft...opt for the aluminum part...just pay closer attn to installation...I use permatex anaerobic gasket maker...less is better than more.....key here is "on a plane".....the aluminum part will take a better beating.....grin
a few years back the plastic red or black bodies were rare....no so today...MECOA molds / sell them....cox inter Bernie and ExModel Matt carry both types
Fred von Gortler IV
Offline Bootlegger
Re: T D 049-051
« Reply #8 on: January 14, 2020, 12:58:48 PM »
 Fellow modelers thanks for your help/suggestions, I got the carb body off today and I wanted to say THANK'S for your help ..  Again thanks..
Gil Causey
AMA# 6964
