  • August 02, 2025, 12:58:50 AM
Author Topic: How to interpret Prather pitch guage readings?  (Read 2320 times)
Offline Mike Scholtes
« on: July 19, 2009, 06:08:21 PM »
The pitch readings for each "station" are different from each other, generally more pitch nearer the hub and less as you move towards the tip. I assume the prop blade is supposed to contact the pivoting arm at about 90 degrees, as shown on the instructions. Said instructions are essentially opaque as to how to actually use the tool. So, where along the blade is the "nominal" pitch? Do you average the readings of all the stations? Is there any general agreement on how to interpret the readings as you progress from station to station?
Offline BillLee
Re: How to interpret Prather pitch guage readings?
« Reply #1 on: July 19, 2009, 07:23:44 PM »
Citing a single number for the "pitch" of a prop is a convenience at best and just wrong at worst. The entire blade of the prop is working as the engine turns it and the model moves through the air. Each place on the blade "sees" the air as a function of where it is on the prop, the rpm that the engine is turning, and the speed of the model through the air. It is common and normal for the measured pitch to vary continuously from the hub to the tip. Properly, the pitch DISTRIBUTION of the prop should be measured, not just a single pitch at one place on the blade.
Bill Lee
Bill Lee
AMA 20018
« Reply #2 on: July 19, 2009, 09:05:34 PM »
I appreciate that the blade pitch changes as you get farther from the tip to account for the increase in speed of each station along the blade as you progress towards the tip (I calculated tip speed on the 14-foot diameter prop on a B-29 as supersonic even at 2500 prop rpm), but we purchase and discuss props as being of a certain diameter and pitch, maybe just as a convention. The Mejzlik 3-blade I tried today on the Enya 61CXS is sold as a "12.5 x 5.2." The diameter is 12.5, but how does the maker decide the pitch is "5.2" rather than one of the 10 other values I measured along the blade? It is slightly over "5" in the fat part of the blade about 2/3 of the way to the tip. Sticking with the Mejzlik line, I also have what he calls a 12.5 x 4.5, which does guage out slightly flatter along its blade length. But how the heck do we decide what prop we are talking about, especially from one maker to another? And still the question, how do I interpret the readings on the Prather guage?
« Reply #3 on: July 19, 2009, 11:04:11 PM »
simple answer, you cant,
the pitch gauge gives you a reference to get a feel for comparative differences. but Ultimatly it is a guide and not absolute. This is because the airfoil each manufacture uses is different and will create a different amount of lift .
The pitch is supposed to be roughly the same number at each station as it moves out on the blade. there is some people that mess with variances in the pitch to creat special effects, IE the tips have a flatter pitch than the root so they dont pull until the plane slows down.
The pitch is a function of the distance the chord travels with each revolution. It equates in theory to the forward helical distance the blade travels per revolution. Normally stated in inches. So a 12 inch diameter prop, the tip will have less apparant pitch when you look at it because it travels a significantly farther distance per revolution than the root does. Hope this helps?
Offline BillLee
« Reply #4 on: July 20, 2009, 04:54:38 AM »
Absolutely right!
Quote from: Mark Scarborough
Again, right on.
Uh, no.  (See your own comment below.)
The pitch is whatever the prop designer decides it should be. Varying the pitch as a function of radius is a tuning activity that can give a prop significantly different performance characteristics. As an example, tweaking the last inch or two of a carbon prop with heat is often done by stunt flyers to make the prop do something different at one point or another in the pattern. (When the flyer does this, he becomes 'the prop designer'.)
If you had said "commonly" instead of "supposed to be", I would have no quibbles.
Some would say "mess with", others would call it "tuning".
Pitch IS the helical distance the blade section would travel per revolution if operated in an incompressible medium. (Think "screw thread".) But it is only a geometrical number. The actual distance the blade moves is a function of a lot of parameters, usually lumped into what folks call "the efficiency" of the prop.
Bill Lee
Bill Lee
AMA 20018
