  • July 17, 2025, 03:07:18 AM
Author Topic: How to improve an old Fox .40 Stunt circa 1970-72?  (Read 2349 times)
Offline frank mccune
« on: June 05, 2015, 05:38:51 PM »
      Any Old Timers out there?
      I have one a couple of those old Stunt .40 Fox engines that I dug out of the attic to use.  After a careful break in I am using one in a Magician with an 11-5 wooden prop. ST nva, RC Long plug, and10% fuel with 28% castor oil.
     The 4-2 break is not crisp and clean but seems to be slow breaking into one or the other.  I have been told that an extra head gasket is the answer.  The engine is a dream to start and needle but so far, the perfect 4-2 break alludes me.  I have been informed that this engine was designed for Stunt by George Aldridge so the timing must be correct.  Perhaps a profile is not a good place to search for that good Stunt break.
     Any suggestions?
        Tia,
        Frank
Re: How to improve an old Fox .40 Stunt circa 1970-72?
« Reply #1 on: June 07, 2015, 01:28:49 PM »
Hi Frank,
I have run a few of those, and always had to take a pretty good while to get the tank height correct on a profile.  No problems in a built up fuselage/inverted engine.  From what I remember the last profile I used one on, the tank was set about 3/16th" high.  Had a lot of flame outs inverted until I got that fixed.
BIG Bear
RNMM/AMM
« Reply #2 on: June 07, 2015, 07:31:31 PM »
     Hi Bill:
     Thanks for the reply.
      This Magician has the tank, a four ounce wedge, inlet into the fuselage so that about 1/2" is projecting on the outside of the body.  I have never seen a profile plane where the tank is installed into the nose.  The tank is on centre line of the engine and is uniflow. I have not had any problems with the engine going inverted.  The engine runs a constant 4 cycle except near the top of a loop etc. when it breaks into a 2 cycle.  Being newer to stunt, I am going to leave the engine as is as it appears to everything that I need from an engine.  I know that I will grow weak and have to add an extra head gasket to satisfy my curiosity. Lol
        Be well,
        Frank
Offline Bill Johnson
« Reply #3 on: June 10, 2015, 04:45:28 AM »
I might be completely off base, Frank, but Randy Smith's tips at the top of this section suggests you might be a little under propped, based on your description. Maybe try an 11-6 or a wide blade prop to load the engine better and get better 4-2-4 breaks.
Best Regards,
AMA 350715
« Reply #4 on: June 10, 2015, 05:14:31 AM »
     Hi Bill:
     Thanks for the tip.  I will make that change.  It is a bit easier to change props than it is to add a head gasket! Lol
     This engine is one of those good Fox products.  I bought it many years ago and broke it in very carefully.  It was in storage for at least three decades and when I put it on the test stand, it started first flip.  It still starts flip.  I am holding my breath hoping that it will not wear out" very quickly.  It is a pleasure when you have a good handling engine! I have a ton of parts to keep this engine running for a long time. As a matter of fact, I bet I have at least one extra engine in the attic.
        Be well my friend,
        Frank
« Reply #5 on: June 10, 2015, 06:31:15 PM »
     Hello BB:
     You're correct! Why the constant search for perfection.  I should just enjoy what I have!
        Be well,
        Frank
« Reply #6 on: June 10, 2015, 08:06:18 PM »
   It should, however, be pretty amenable to *small* tweaks, and if nothing else, if you are careful, you will learn something. The weak/slow break is a classic sign of either not enough oil, or not enough compression ratio. A *very small* (like a .003 thinner head gasket) should have a minor but detectable effect and improve the sharpness of the break. Either that, or add 3% castor to the fuel, and see what happens. Be careful to control the other conditions and observe carefully.
