  • July 25, 2025, 02:12:24 AM
Author Topic: How to break in an engine with 1 BB and one ring?  (Read 1034 times)
Offline frank mccune
« on: June 12, 2013, 02:44:01 PM »
     Hello All:
     I am currently attempting to break in an older O.S. .40S that is new.  I searched the web but I did not get a definitive answer.
     I have run it with a cut down prop that is now a 9X6 at about 9000 rpms.  This is a very slow rich but steady 4 cycle.  I have run one quart of fuel through it this way.
    What do I do next? Perhaps about 30 minutes with a 10X6 prop at the same rpms? I want to put it into a stunter when it is broken in where I may fly it without it overheating.
     The instructions for the O.S. .35 Stunt calls for a 20-30 minute run with a 9X6 or a 10X6 prop and an additional time of 20 minutes in a two cycle mode.  The .35 is a lapped engine with a bushed crankshaft so we are not talking aples=aples.
       What are your suggestions?
        Tia,
        Frank
Re: How to break in an engine with 1 BB and one ring?
« Reply #1 on: June 12, 2013, 03:14:39 PM »
Hi Frank,
I asked Randy basically the same question.  He says to mimic the older iron piston/steel sleeve break in.
http://stunthanger.com/smf/index.php?topic=29918.0
Offline Brian Hampton
« Reply #2 on: June 12, 2013, 09:34:04 PM »
Pretty much as Randy said in the above link although I'd suggest a fuel with at least 20% oil with a fair bit of castor. Personally I use 75/25 all castor for all types of engines (iron through to ABx). With the old H-40S using a bushed front end I'd continue using a fuel with a fair bit of castor after it's run in. Some day I'll have to give mine a run too :).
