CLICK HERE--><--CLICK HERE
How much tank height adjustment??
Started by Steve Glass, August 04, 2026, 07:04:15 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Steve Glass
I'm Building my first full fuselage model (Legacy 40)
How much room should I have in the tank bay for height adjustment?
Tim Wescott
As much as you need? As much as will fit?
I have no fear of tearing a tank open and relocating the uniflow vent.
If you have the uniflow vent close to the right spot, then you don't need to move the tank more than plus or minus 1/16 of an inch.
That means that I'm going to aim for about an eighth of an inch up and down movement of the tank. If I fly the thing and moving the tank all the way to the top or the bottom of the compartment isn't enough, then I will take a guess at how much the uniflow vent needs to be moved, I will take out the tank, and I will move the vent.
Once the vent position is settled, then the remaining space to move the tank up and down will pretty much take care of any further adjustment.
Steve Glass
Thanks Tim, just the information I was after.
I'll be making my own tank so any surgery shouldn't be a problem.
Brett Buck
Quote from: Steve Glass on August 04, 2026, 07:04:15 AMI'm Building my first full fuselage model (Legacy 40)
    If you have absolutely no idea, then make it reasonably big (1/4"-3/8"). But once you have some idea, then, the shims are typically around 1/64 just to fine tune it.
   What engine do you have? someone probably already knows a reasonable starting point.
Steve Glass
Quote from: Brett Buck on August 04, 2026, 12:18:55 PMWhat engine do you have? someone probably already knows a reasonable starting point.
Brett,
I want to use an Enya 45 fitted with a Brian Gardner ABC p/l. The Enya is powering a Fancherised Twister at the moment, mounted sidewinder, so that doesn't help much?
With a 1" thick tank I'll only have 1/16" of up adjustment before the tank hits the crutch that I've made. Down adjustment of the tank is not a problem as I've yet to fit the tank floor.
BillLee
I don't fly stunt, so what do I know. But if it was me, I would start with the tank positioned so that the uniflow point inside the tank was at the same level as the needle valve of the engine. Then move from there as flying would dictate.
Like Like x 1 View List
Bill Lee
AMA 20018
Peter Klosky
On a profile like a Twister, my favorite rig is to mount the tank on a small platform.  The platform has elongated holes to bolt it to the fuse.  A starting point is about 1/8" higher than the spray bar, but the elongated holes allow 1/5" freedom in each direction, field adjustable.  Also, the platform has a stop at the front to prevent tank movement in a crash.
Peter
Dave_Trible
You may be approaching this with a predetermined idea as to tank THICKNESS.  Nothing says it has to be 1" or whatever.  As long as you have the length and width to work with a little you can make the tank a little thinner and give yourself the 'space' to shim it up or down.  Having said that I make my tanks 1 3/8" thick for my RO Jett engines, then start out from building with aluminum shims -around 1/32"- under the engine that would allow me shim the tank closer to the mounts if need be.
BillLee
Keep in mind OP is building a  full fuselage model, so profile mounting doesn't really mean much.
Bill Lee
AMA 20018
Peter Klosky
Thanks for that correction.  Yes, I'm now seeing that the above reference to the Twister referred to the existing plane, not the one under development.
Regarding tank shimming, my experience is that the typical limitation is the the tank needs to be able to be higher than the design allowed for.  In practice, engines run rich inverted.
Peter
Steve Glass
Excellent suggestions here.
Shim the engine 1/16" and a 7/8" tank will give me 3/16" up adjustment before hitting the bearers.
Ken Culbertson
Quote from: Steve Glass on August 05, 2026, 12:26:59 PMShim the engine 1/16" and a 7/8" tank will give me 3/16" up adjustment before hitting the bearers.
I don't normally fly IC motors anymore, but when I did I made the tank box 1 1/4" tall and used an old set of playing cards for filler.  Move it up: Take cards out of the top and put them in the bottom.  Move it down: Take cards out of the bottom, and put them in the top. Always have the right number of shims with you.
Dave Hull
And when the engine won't run right, you switch out your full house for a straight flush?
Ken Culbertson
Quote from: Dave Hull on August 05, 2026, 05:59:45 PMAnd when the engine won't run right, you switch out your full house for a straight flush?
Ace high!  LL~
Stephen Franco
Quote from: Peter Klosky on August 04, 2026, 05:40:44 PMOn a profile like a Twister, my favorite rig is to mount the tank on a small platform.  The platform has elongated holes to bolt it to the fuse.  A starting point is about 1/8" higher than the spray bar, but the elongated holes allow 1/5" freedom in each direction, field adjustable.  Also, the platform has a stop at the front to prevent tank movement in a crash.
Peter
Like many before me, I'm getting into c/l after a few decades of hiatus following my childhood plastic Cox jobs. Have been flying r/c for many years.
Apparently you don't have trouble with fuel foaming from engine vibration transmitted via the solid tank mounting.
Is this no-foaming worries a feature of the metal uniflow tanks?
Thinking about a Veco(Brodak) Tomahawk for a Veco19BB I just scored.
It's a wonderful life.
Dave Hull
No, fuel foaming can be a problem. Metal tanks are NOT immune.
All the usual fixes still apply. Balanced prop. Balanced spinner. Prop tracks straight (in-plane; no "whorl.") Reasonably stiff nose. Some mount the tank on foam pad (as is common in R/C). Some use plastic tanks that seem to suffer less from foaming. (At least mine have.)
But sometimes you end up with a combination that is just bad. A certain engine, prop and nose with just the "wrong" stiffness and the thing resonates. Old, oil-soaked planes usually really suffer.
An in-line fuel filter sometimes helps. The expedient of adding a fuel surfactant is often done, but causes other problems. There are a thousand posts already on the use of Armorall. Don't really want to start another one....
Creative Creative x 1 View List
Stephen Franco
I'll admit it did not seem possible that metal uniflo tanks were immune to foaming the fuel, but after seeing references to solid mount setups, thought I would check.
Thanks for the reply.
Colin McRae
Quote from: Stephen Franco on September 18, 2026, 10:28:44 AMI'll admit it did not seem possible that metal uniflo tanks were immune to foaming the fuel, but after seeing references to solid mount setups, thought I would check.
A majority of my models use metal uniflow tanks from Brodak, solid mounted. I don't use rubber bands but use aluminum tank straps bolted to the fuse.
If fuel foaming is occurring I surely don't notice any ill effects. Engines run fine.
Colin
Steve Helmick
IF it comes right down to it, and you don't have enough tank height adjustment, you CAN fabricate a tank that has an assymetric cross section that puts the fuel pickup and uniflow tube higher in the tank...kinda like Tim suggested, but designed that way, instead of fiddled with to make it work. You might also make the tank taper from front to back (smaller at front) to get a cleaner engine-off than the burp-burp-burb nonsense we sometimes see. That's often cured by shimming the back of the tank outboard, but is often caused by the leadouts being too far aft. The question is, do you want to make your own fuel tank? A good start is to fabricate a hardwood or aluminum form the shape you want, to bend the sheet tin around...and then use it to bend the end caps to fit. Yep, takes practice.  Steve
Dave_Trible
#19
Quote from: Stephen Franco on September 17, 2026, 03:11:57 PMLike many before me, I'm getting into c/l after a few decades of hiatus following my childhood plastic Cox jobs. Have been flying r/c for many years.
Fuel foaming is seldom an issue on full-fuselage airplanes but can be a problem on profile fuselages.  Smaller airplanes likely not too big an issue and where you are running the engine almost totally flat out in a two cycle scream you probably won't tell the difference anyway since that is what fuel foaming does.  Your Veco .19 is one of those that really only runs that way consistently.  Where you might be trying to run a 2/4 break is where it shows itself a big problem.   I have had very little success trying to run an engine larger than a mild .40 on profiles.  The FP .40 does well but again in the two cycle mode.  The LA .46 CAN cycle pretty well on a solid airplane and props not oversized.  We have a Tigre .46 on a profile that is doing OK.  We built a few profiles in the .50-.60 class and have mostly frustration trying to get good runs due to vibration,  even fiberglassing the fuselage.  We've resorted to the two cycle concept with these and the Magnum .52 or .53 to make them usable.  Nothing else in our engine inventory will run as desired on a profile.  My current profile airplane has an Enya .45.   I've had run problems with that,  tried three different engines and two tanks.  I'm finally getting pretty good runs but had to go to a smaller, lighter prop.   I have a BY&O 11-6 wood on it that is pretty smooth.   Going up just a bit to a Rev up 11 1/2-6 was too much as was cut down 12-6s .   I've not tried any heavier 11-6 like APC or Zoar but would expect vibration to be magnified with them.  I'm thinking if I do more profiles in the future to just drop back to .35s or really mild .40s.  That should eliminate most these issues.
