  • July 25, 2025, 03:44:35 PM
Author Topic: How much nitro for Stunt and Sport Flying?  (Read 3438 times)
Offline frank mccune
« on: December 29, 2014, 02:06:56 PM »
     Hello:
     How much nitro should I use in my fuel for Stunt and Sport flying?
        Tia,
        Frank
Online Howard Rush
Re: How much nitro for Stunt and Sport Flying?
« Reply #1 on: December 29, 2014, 02:34:02 PM »
At least 40%.  Why screw around?
« Reply #2 on: December 29, 2014, 02:49:05 PM »
Howard, there are kinder ways to proselytize for electric power.
Frank:  As much as you need.  Depending on engine and plane you probably want between 5% and 15%.  If you have something to prove, mess with engines and planes until you can fly well with FAI fuel (0%).  If you have a very tediously underpowered engine, go up in nitro -- although, if you're getting above 25% in a 35 or bigger engine, then you probably want to investigate different engine options for that particular airframe.
« Reply #3 on: December 29, 2014, 04:35:43 PM »
Frank,
A lot depends on what your source for purchasing fuel is. Try to get fuel that has at least 22% total oil for ABC, AAC, ABN (basically modern OS FP's, LA's etc.). If you are running an iron/steel engine (Fox, old OS Max, McCoy's, K&B green heads etc.) you want to get fuel with at least 25 - 28% total oil with at least a 50/50 castor/syn blend (high castor won't hurt up to 90%). For the iron/steel engines stay away from R/C fuels (Cool Power) as they don't run well in stunt (very low oil). With that said most modern engines run well on 10 -15% nitro depending on where you fly (higher altitude like Tucson, AZ run higher nitro). The iron/steel with be running at lower rpm and 5 - 10% nitro is fine.
Read Randy's Care and Feeding article at the top for more information.
Best,       DennisT
« Reply #4 on: December 29, 2014, 05:41:33 PM »
      Hi All:
      Thanks for the replies!
      As I mix my own fuel, I am able to blend what I want.  I was thinking of the following mixes for my engines:
     Cast iron and steel engines will get 5% nitro, 24% castor 5% Klotz remainder alky.
     For my Brodak .25 I will mix one batch of 5%, 11% castor, 11% Klotz and the remainder alky. This is the only "modern" engine that I use! Lol
      In the Old Country in the 70's, I used FAI fuel with 29% castor oil in one loacation.  I paid $3.00 per Imperial gallon for pure USP Castor Oil in 1973.  The alky was free.  That fuel seemed to run very poorly especialy in .049 engines! In anothe area. I could only get Klots 100 and alky and I ran it at 29% oil.  This mix worked in the .19-.40 engines.
     I noticed that my friend was running LHS fuel that only contained 15%-17% total oil.  I suggested that he may want to add some Castor Oil and he said ,"Why? My engines run great on that fuel." What can I say? Lol
                                                           Stay well my friends,
                                                           Frank
« Reply #5 on: December 29, 2014, 06:44:16 PM »
     Hello:
        Tia,
        Frank
What engines? How hot is it there, and how high is the altitude? Need more info that wot we got!  D>K Steve
Offline Balsa Butcher
  • High Desert Flier
« Reply #6 on: December 29, 2014, 11:28:46 PM »
How much Nitro for sport and stunt flying? Short answer:10%  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Chris Wilson
« Reply #7 on: December 30, 2014, 02:20:55 AM »
Nitro equates to oxygen, the less of it above sea level the more you are going to need to keep a constant run.
MAAA AUS 73427
« Reply #8 on: December 30, 2014, 02:23:13 AM »
  If you have a very tediously underpowered engine, go up in nitro .
Tim, what about upping the compression ratio and sticking with just FAI fuel?
Works with MVVS engines nicely.
MAAA AUS 73427
« Reply #9 on: December 30, 2014, 06:04:50 AM »
    Hi:
                                                Frank
Offline bob whitney
« Reply #10 on: December 30, 2014, 03:06:01 PM »
  the other part of the equation is if it is a ball bearing engine or not  a BB,ABC needs the least oil of all a bushing engine needs more lube
rad racer
« Reply #11 on: December 30, 2014, 06:20:40 PM »
Hi Bob,
Not sure what a nitro question has to do with oil content but 99% of all model engines have to suffer from a plain bearing big end and since that is the most stressed part of any engine I would use an oil content based around that.
MAAA AUS 73427
« Reply #12 on: December 30, 2014, 06:35:26 PM »
Dunno about that -- but I'll believe you unless personal experiment proves otherwise.
It may not work with all engines, and it may not end up with an engine that has a nice "stunt run" -- but here again, I have no personal experience to go by.
Offline Brian Hampton
« Reply #13 on: December 30, 2014, 08:02:54 PM »
Been there and done that (raising compression for FAI fuel). Standard (geometric) compression on the Enya 61 RE is 8.8:1 and gave a nice 4-2-4 run but after about 40 flights I raised comp to 12.4:1 which gave a broader 4 stroke range and better 4-2-4 break which I've stayed with ever since. Back to back testing on the test stand (enough time to swap head buttons) showed an increase in HP of 26% when peaked out. I've never used nitro in any engine so can't guess at how much nitro would be needed for a similar HP gain. What you DO get using nitro is a broader acceptable needle setting and is a simple way to adapt to different elevations. Something we don't really have to contend with in Australia :).
