Well I have been using this motor in an Oriental full fuz model.
Has about 20 flights on it after running in on test bench,it runs
nice but has one problem,it bogs down rich after the recovery
to normal upright flight from the three outside loops,same again
in the last inside loop of the clover,its like fuel is pooling up in the motor
then tries to drown the plug the rest of the pattern is fine,Sig R/C glow
plug with idle bar,fuel is 11.5 % klotz,11.5% castor,3% nitro& remainder
methanol,11 x 5 Brodak smooth finish prop,have tried a number of hot plugs
same result release RPM about 9,100,uses 90cc of fuel for 6min 30 sec flight.
Still able to complete the pattern just a little worried about it stopping in the
climb out from the clover.
Randy any suggestions?
