  • June 20, 2025, 09:59:44 AM
Author Topic: Hot Fox syndrome  (Read 777 times)
Offline Russell Shaffer
Hot Fox syndrome
« on: September 24, 2008, 08:50:05 PM »
You guys probably know all about this, but I just discovered today that a wet paper towel wrapped around a Stunt 35 while you untwist the lines and refuel makes the restart much easier.
Russell Shaffer
Klamath Falls, Oregon
Offline Bill Heher
  • Fix-it
Re: Hot Fox syndrome
« Reply #1 on: September 25, 2008, 07:58:11 AM »
We used to drip fuel on the case of my Fox .19 that had a loose / worn Piston to Liner fit. That and a shot of striaght oil in the exhaust to seal it better for that " 1 flip restart".  Unless it didn't start, then you just kept flipping that prop till your arm falls off !
Bill Heher
If it's broke Fix-it
