  • June 25, 2025, 08:08:31 AM
Author Topic: Hey Randy S-OS.25VF  (Read 791 times)
Offline James Strickland
Hey Randy S-OS.25VF
« on: September 02, 2012, 11:57:36 PM »
Randy or anyone who knows,
What is the weight of an OS.25VF & its timing for a pipe when set up for stunt?
Thanks, James
Re: Hey Randy S-OS.25VF
« Reply #1 on: September 03, 2012, 04:20:50 PM »
HI James,
I have one, but I cannot tell you the weight, I don't remember..........  :'(
It's on my "bucket list" to use on an Ares size model.  I have a .32 pipe for it, but I will have to call Randy and ask him the pipe length to start with.
BIG Bear
RNMM/AMM
Offline Paul Allen
« Reply #2 on: September 04, 2012, 12:59:57 AM »
James
         I have run the VF in an Oriental, weight is 8 oz's with a Mac's header, RPM 10,700, pipe length 17.5"
fuel- 10% nitro, 10% Klotz, 10% Castor, it uses 95cc , on 61ft 0.015" lines E to E. Prop 10x4 APC.
Engine timing as near as I can measure - Exhaust 150 degree's ( total), Inlet 120 degree's ( total) , Crankshaft 193 degree's.
Randy pipe.
In OZ
« Reply #3 on: September 04, 2012, 01:42:18 AM »
I have an OS .25 VF modified by Randy.  His venturi, ST needle.  I just weighed it at 7.5 oz.  His tuned pipe is 1.4 oz.  I did not weigh a header.  Timing by Randy.
