What Steve said. If the jug was not sealed and it was stored in a damp space, it may have absorbed moisture. Try freezing the whole jug and then pouring it through a strainer. The fuel wont freeze but the water might. If the strainer comes up with leftover ice pellets, try running it again. If it still cuts out, try a one tank sample of the fuel, with 1-2% igniter added. This can be acetone, propylene oxide or lighter fluid. If that works, then add igniter to the whole jug and use it up. Go slow on maneuvers until you have a couple of reliable runs.
