  • July 04, 2025, 06:59:43 AM
Author Topic: Help with 46LA backplate  (Read 2199 times)
Offline MarcusCordeiro
« on: January 05, 2013, 04:38:59 PM »
Hey guys
Could anybody tell me where I can find a metal backplate for a 46LA?
I can't seem to find it anywhere.
If anybody has one not in use, I'd be happy to buy...
Thanks a million
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Re: Help with 46LA backplate
« Reply #1 on: January 05, 2013, 04:49:06 PM »
http://stunthanger.com/smf/index.php?topic=29686.msg289673#msg289673
The FP 35/40 and Tower 40 backplate will fit, but this late in the game they're hard to find without an entire engine attached to them.
« Reply #2 on: January 05, 2013, 05:32:56 PM »
Marcus
Aces High!
Offline Mike Callas
« Reply #3 on: January 05, 2013, 11:01:04 PM »
Curtis Shipp makes these
Curtis Shipp
P.O. Box 1255
Glendale, Al 35071
« Reply #4 on: January 06, 2013, 05:18:32 AM »
Curtis Shipp
P.O. Box 1255
Glendale, Al 35071
Mike is correct!
Curtis does great work. I purchased one from him.
Charles
« Reply #5 on: January 06, 2013, 04:48:59 PM »
Thank you so much guys.
Does he have email??
Marcus
Aces High!
« Reply #6 on: January 06, 2013, 08:48:34 PM »
A small bead of gasket sealer(silicone) in the corner will make sure it doesn't leak.  Doesn't take much.
« Reply #7 on: January 07, 2013, 03:37:59 AM »
Yeah, but the backplate is broken... When my son landed his Nobler on the nose after a failed loop, the very nice needle bracket broke off, and apparently it was ok, but after  couple runs, the leak was big, and I don't think I can seal that... >:( >:(
Anyway, let's solve this little problem and get that engine back in action.
By the way Phil, did you get my email??
Marcus
Aces High!
« Reply #8 on: January 10, 2013, 05:12:41 PM »
Hi Marcus,
Go to the "Members" tab and click, then click on the "D".  Curtis is about 1/2 way down the page, next to last of the "Cs".  His email address is there.
BIG Bear
RNMM/AMM
« Reply #9 on: January 12, 2013, 10:44:42 AM »
I have sent him email but got no answer... for now I've replaced for another plastic one, but really wanted the metal.
Thanks anyway Bill.
I'll try again
Marcus
Aces High!
Offline Luiz Ribeiro
    • Ribeiro's Home Page
« Reply #10 on: January 14, 2013, 12:49:46 AM »
Marcus,
The aluminum back plate of Thunder Tiger GP-42 has just 0.2 mm more in diameter than the back plate of the OS LA 46 and it fits perfectly in the LA 46 if you take out this aluminum excess in a lathe. Some years ago I bought two of them in Tower Hobbies ( 6.00 USD each) and sent together an original in nylon, as model, to our friend Daniel of CB Motores at 1501 Interlagos Ave in SP and he did the work in the lathe, which is very easy for him. They fitted perfectly in the 46 LA, but particularly I didn’t see much difference in performance using a metal back plate or the original in nylon. The back plate of the .40 FP fits perfectly, too, but we don’t find them in the market.
Luiz
« Reply #11 on: January 14, 2013, 11:16:44 AM »
Hi Luiz,
The metal backplate is not for increased performance, but instead it is for preventing leaks.  Unless you carefully use a silicone sealant on the plastic one, they leak in about 99% of ones used.  Just over tightening (doesn't take much) the backplate bolts can cause a leak with the plastic backplate.  I don't have time to put up with a leaking backplate if it can be prevented.
BIG Bear
RNMM/AMM
« Reply #12 on: January 14, 2013, 02:53:32 PM »
Hi Bill,
Thanks for the information, I have never measured but I have to agree with the expectation that you presented of a high probability of leak failures in the case of a plastic back plate.
Luiz
« Last Edit: January 15, 2013, 02:52:49 AM by Luiz Ribeiro »
