  • June 21, 2025, 05:56:06 AM
Author Topic: Needle Valve Assembly Enya .15III?  (Read 1066 times)
Offline Tom Luciano
« on: February 16, 2007, 08:06:27 PM »
Guy's,
  I picked up A Enya .15III  the other day in almost new condition but the NVA is broken. Any recommendations on a replacement I tried to contact MRC but haven't heard back from them. Any aftermarket or any other brands work on this engine? I see  a lot of discussion on Super Tigre  NVA's.
AMA 13001
Offline dennis lipsett
Re: Needle Valve Assembly Enya .15III?
« Reply #1 on: February 16, 2007, 08:28:25 PM »
You can use the OS15 NVA from the FP 15. That is available from Tower. Altech dosn't answer emails you whave to call and Carol will take care of it for you.
Dennis
Offline Tom Luciano
« Reply #2 on: February 16, 2007, 08:43:12 PM »
Thanks Dennis
Tom
AMA 13001
Offline ken cook
« Reply #3 on: February 23, 2007, 03:43:54 PM »
              I was using a OS needle for the 35-40 engines.This was working fairly well.My Enya III was a r/c conversion.My father had the 3304 model which came with 2 venturi sizes.I don't recall the exact sizes,but I used the larger of the two. The engine runs have been pretty effecient except for the end of the run. I get some real lean runs at times nearing the last few laps. I'm using a tongue muffler with muffler pressure on standard vent tank.I'm using a 2 inch oval which fits the nose real well. I might switch to uniflow after 1 more experiment. I recently picked up a FP .15 needle which I just installed. Its too cold to fly currently. I noticed the needle was identical but the spray bar was turned down considerably in the venturi area. I hope this means more fuel for me which might calm down the leaning out. In the event that you do try a FP .15 needle first,I'd like to hear the results. It looks like another few months for myself.                            Ken
Offline Tom Luciano
« Reply #4 on: March 03, 2007, 06:19:54 AM »
Hi Ken,
  I ended up calling MRC and they had the NVA in stock so I just went with it ,$9.00 plus shipping
         Tom
AMA 13001
