Hey Steve - Always. Mine is a 1/4 inch slice of foam, encased in a plastic bag, under a shield made of .010 aluminum roof flashing. Use servo screws to hold the shield, insulation and tank in place.
How many of you guys run some sort of heat shield or baffle to keep heat from the header off your fuel tank?
