  • July 15, 2025, 12:14:54 PM
Author Topic: Heat differences between chip mufflers and expansion type of mufflers?  (Read 861 times)
Offline frank mccune
    Has anybody ever done a test to determine if and how much of a difference in heat each of these mufflers produce while running? Results?
        Tia,
                                                               Frank
    It's highly variable between specific mufflers, so, it's more-or-less impossible to answer in general. In any case, you choose the muffler or settings that make the airplane fly the best/engine run the best, regardless of the temperature. If it melts or seizes, then it won't fly the airplane very well; Otherwise, its OK.
   You can make tongue mufflers either more or less restrictive or retain more or less heat by blocking some of the holes. This was a very common technique back before mufflers became obsolete.
