  • July 08, 2025, 02:18:21 AM
Author Topic: Head Gasket?  (Read 977 times)
Offline fernando torres
Head Gasket?
« on: November 21, 2006, 05:26:57 AM »
I removed the cyllinder head on a 40th anniversary Fox 35. There was no head gasket. Is that ok? or should it have one.
FET
Offline Ralph Wenzel (d)
Re: Head Gasket?
« Reply #1 on: November 21, 2006, 06:00:43 AM »
There really should be a head gasket. Because the Fox gasket is dead-soft aluminum, it sometimes isn't obvious that there is one. Sometimes I find it necessary to use a straight pin to "pick at" the edge of the gasket from one of the bolt holes in the head.
Do this gently, or have a spare gasket on hand.
Ralph Wenzel
AMA 495785 League City, TX
Re: Head Gasket?
« Reply #2 on: November 21, 2006, 07:30:30 PM »
The Fox gaskets are so soft that you don't really have to worry about damaging them, unless you really tear notches in it or scrunch it up into a ball.  Flatten it out a bit and the head will squish it right down when it is reinstalled.
