  • June 21, 2025, 12:07:53 PM
Author Topic: Head Bolt Torque?  (Read 1841 times)
Offline Dennis Saydak
Head Bolt Torque?
« on: May 26, 2015, 02:49:59 PM »
What's the proper torque setting for Super Tiger head bolts?
Offline Phil Krankowski
Re: Head Bolt Torque?
« Reply #2 on: May 28, 2015, 05:23:26 PM »
Thanks for your reply Phil. I had to install a head gasket in my engine and while I was at it I replaced the stock head bolts with socket head bolts. I have a Wheeler FAT torque wrench which I used to tighten the bolts. First I progressively used the wrench to tighten each bolt until the new head gasket stopped leaking air. Then I tightened each bolt 1/4 turn more. The result was a perfect seal with awesome compression. I couldn't have done the job without my torque wrench though. Unfortunately I didn't record the torque setting but if I need to ever do it again I can always use the wrench to determine the current setting and go from there.
« Reply #3 on: May 28, 2015, 06:38:24 PM »
That's a well thought out process.  Did you run it yet?
Phil
« Reply #4 on: May 29, 2015, 01:55:32 PM »
It's missing a venturi and NV assembly. I got it from a friend's estate sale and it was missing these parts. Otherwise, it's in perfect unused condition. Not sure what I'm going to do with it though as I have plenty of other engine choices.
Offline frank mccune
« Reply #5 on: May 30, 2015, 05:53:38 AM »
     Hi Dennis:
I have a question.  Why did you tighten the head bolts one quarter of a turn more after the gasket stopped leaking?
        Stay well,
        Frank
« Reply #6 on: May 30, 2015, 07:26:12 AM »
     Hi Dennis:
        Stay well,
        Frank
Extra insurance for a proper seal. Also to prevent any small leakage that I missed.
Offline Bill Johnson
« Reply #7 on: June 02, 2015, 10:07:05 AM »
Determining proper torque without manufacturers guidance is always a tricky proposition. You have to know the size, thread pitch and grade of bolt. Then you have to know what the material is it's being threaded in to. Next is whether the torque is applied with threads wet or dry (with oil).
I have 6 different specifications for applied torque for any single fastener based on application. In the end, I did the same thing you did, Dennis. Saturday I put together a couple Enya 15s and torqued the screws until the head stopped leaking plus about 1/4 turn per screw.
Best Regards,
AMA 350715
