  • June 19, 2025, 06:37:08 PM
Author Topic: Hayes Tanks  (Read 1082 times)
Offline Paul Seeley
Hayes Tanks
« on: August 22, 2017, 05:52:32 AM »
Hi all - currently building a new Rindmaster profile light for fun using a plan very kindly sent to me by Floyd Carter - Hats off to you sir  #^
Hopefully get it all done and dusted so I can fly in the world wide event in early October. Anyway build progressing nicely and I've recently acquired a couple of OS 25's from a clubmate for it. I'm looking to use the OS Max 25 because it's a bit lighter than the later version and it already has a stunt venturi fitted.
I wanted to use an inboard tank but I can't find a supplier for the recommended Hayes 3 oz tank. It appears that they are not available over here so is there an alternative or will any suitably sized and plumbed clunk tank do the job?
Cheers
Offline badbill
Re: Hayes Tanks
« Reply #1 on: August 22, 2017, 06:08:29 AM »
Bill Davenport
AMA 28141
Offline John Eyer
Re: Hayes Tanks
« Reply #3 on: August 22, 2017, 12:40:08 PM »
AFAIK, Hayes is no more.  That 90CC tank from Hobby King should do, however.
