  • July 16, 2025, 05:01:19 AM
Author Topic: Have you ever burned up an engine when running castor oil as a lubricant?  (Read 979 times)
Offline frank mccune
      Hi:
      I recently had the misfortune to have two engines go very very lean while flying.  I mean that they finally stopped running from being too lean.  These engines were rally cooked when they finaly landed.
      The engines in questioin were a 1950's Fox .25 and a 1970's O.S .35 stunt.  When they cooled down, they both had great compression with no noticable leak down.  They started wih about two flips each.  The engines were black and brown on the outside and the pistons had a black residue on the sides of the pistons.  This residue ended about .125" down fron the top of the piston.
      I was running "Club Fuel" that started with 10% nitro and 25% castor oil.  I added 4 oz. of castor oil to the gallon of fuel just incase I did have a lean run!
     Years ago, a chap with whom I became friends with, insisted that one could not hurt a cast iron and steel engine if one used all castor for a lube.  Perhaps he was correct!
      What about it?  Have you ever ruined a cast iron and steel engine when you were using a high percentage of castor oil?
        Stay well,
        Frank
Frank,
In most cases a lean run with a lapped piston on castor will not ruin the engine. The biggest problem is if it seizes up. The times I've had them go really, really lean they just sag and quit I just let them cool. Next fined the problem (dirt in the NVA, tank vent cap left off on uniflow tank, wrong fuel - grabbed the 25% can instead of the 5%). Once cool put in a few drops of after run oil and check how the engine feels. If it flips normal with a good pop, should be ok, I would open the needle 1/2 turn, let it run rich a little bit then retune and fly. If it starts to sag try to run a couple tanks of 50/50 sync/castor to clean it up. If that doesn't work you will need to pull the head and de-varnish with a small piece of green Scotch brite pad.  Once you get the varnish off the cylinder, clean out with a few squirts of fuel put in some after run oil put the head back on and run a few tanks of 50/50 very rich to get things seated. Should be good to go. If that doesn't do it either get an piston/sleeve assembly or a new motor.
Best,       DennisT
