  • June 22, 2025, 09:10:20 AM
Author Topic: Have a pipe, need an engine.  (Read 1206 times)
Offline Chris Wilson
« on: August 31, 2014, 11:01:20 PM »
Hi all,
       I have a tuned pipe that came from a PA 75 (at least that's what I was told it came from) and am trying to justify an engine for it other than a PA.
Any ideas on what engine this monster pipe may suit? Enya 61 maybe?
I can supply the pipe measurements if needed.
Thanks.
MAAA AUS 73427
Re: Have a pipe, need an engine.
« Reply #1 on: September 01, 2014, 08:31:13 AM »
Chris the Enya would work I think but I'd go RO Jett .61-.76.  If the pipe did actually come from a .75 it's a larger pipe than you'd typically use on a .60-.65.  It may still work OK but I've not tried that mix of pipes and engines.  The .75 PA and .76 ROJett use the same pipe.
Offline Martin Quartim
    • StuntHobby
« Reply #2 on: September 02, 2014, 12:11:11 AM »
I use Brian Eather #9 and Randys PA 75 pipe with the Enya 61CX and it works very well.
Martin
