  • June 21, 2025, 04:28:43 AM
Author Topic: screw tightening with btorque driver  (Read 782 times)
Offline dssit
« on: August 13, 2007, 06:23:39 AM »
where can I find torque in inch pounds for head and case bolts
Online Perry Rose
Re: screw tightening with btorque driver
« Reply #1 on: August 13, 2007, 05:42:46 PM »
Torque screwdrivers are available in in. lb. and in. oz. ranges. generally from zero to 36 in lb. and I can't remember
what the in. oz. range is. Try Proto tools. The tool has a 1/4 in. square drive so you will need a socket or some
other adapter to hold the bit or allen wrench. Snap-On has dial torque wrenches that may fit the bill also.
Perry Rose
Offline Ralph Wenzel (d)
« Reply #2 on: August 14, 2007, 12:08:18 AM »
If you're looking for a chart of the proper torque for the various screw sizes, also remember that what the screw goes into is just as critical as the screw itself. Aluminum is soft, compared to most any screw material except solid brass. See also:
http://raskcycle.com/techtip/webdoc14.html
http://www.thelenchannel.com/1torque.php
The second one is probably the one you really want . . .
Ralph Wenzel
AMA 495785 League City, TX
Offline dssit
« Reply #3 on: August 14, 2007, 10:34:34 AM »
thanks ralph just what I needed
Offline Ward Van Duzer
« Reply #4 on: August 15, 2007, 09:30:00 AM »
Randy also sells a breakaway torque driver.
W.
