  • June 21, 2025, 04:14:29 PM
Author Topic: good choice or not  (Read 1477 times)
Offline W.D. Roland
good choice or not
« on: August 17, 2006, 01:16:33 AM »
dont know if this will make a good one or not. anyone?
all i remember about this engine that we spent alot of time and money on it.
it has 2-4 flights on it( dads se5a bit the dust due to hard head)
it didnt impress me as being a  full fledged teenage combat junkie i needed all the horses per hour i could get.
i do remember it would pop the #%^& out of me when id start it for him.
engine specs
 S.T. .35 stunt
  hemi/button head
  chrome sleve
  oil groved piston (notice we didnt cut groves in wrist pin area)also top edge has been relived
  case is machined to lower sleve and port timing and true it up.
i plan on using this engine and have know idea what to expect
  David
David Roland
51336
Offline Manuel Cortes
Re: good choice or not
« Reply #1 on: August 18, 2006, 03:53:49 AM »
Hello all!
I used one of them several years ago, pulling a Nimrod (Jim Mannall design) and a Nobler.
VERY sweet engine, delightful break (one of the mildest I´ve heard).
Mine pulled a 10x6 at 8.500 rpm (just in the edge of 4-2 break) on the ground and was enough for a 38 oz model.
Fuel 25% castor 5% nitro.
My personal opinion, very good choice for any classic design.
Regards from Spain. y1
« Reply #2 on: August 18, 2006, 07:10:07 PM »
Hi David,
While I have seen several of the "stunt" (baffle piston) ST 35s run (like yours) I don't have a clue as to how it will run with the mods that have been done to yours.  But taking a guess, I would believe it would be exceptional!
The "stock" ones are really good.  Even the flat top piston ones will run a pretty good 4-2 with the right venturi and shims.
Go for it!
Bill <><
Offline L0U CRANE
« Reply #3 on: August 18, 2006, 08:27:44 PM »
Where have I seen this before??
\BEST\LOU
Offline W.D. Roland
« Reply #4 on: August 23, 2006, 03:22:15 PM »
i dunno Lou
memories are fading fast around here.
so many people we knew and dont remember.
Do you?
David
David Roland
51336
