  • July 04, 2025, 02:11:42 PM
Author Topic: .. Goes rich...  (Read 1355 times)
Offline Bootlegger
.. Goes rich...
« on: August 27, 2007, 05:52:06 AM »
 Mornin fellows,
   I am flying a full fuse stunter with an OS 32 SX that we have hemi shaped the head and blocked the boost port.
  Flying with an apc 10x5 prop on 5% 11-11 Powermaster fuel.
 The engine starts off running real well then at about half way it starts to richen up. The tank is a metal tank on uniflow open to the atmosphere. Does any one have any suggestions ???
         Randy or anyone...Thanks, Gil
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Chris Gilbert IRL-1638
  • EI-1638
Re: .. Goes rich...
« Reply #1 on: August 27, 2007, 06:29:20 AM »
I'll assume you've checked all the usual stuff, no pinholes in the tank, no holes in the tubing.
Now, is it actually going rich, or is it losing power?
I had an LA that I thought was going rich mid way through the schedule, but it was actually overheating and loosing power as a result, it'd stagger around until the motor cooled enough to run right (or ran out of fuel).
Had me scratching my head for a few flights, until I figured out the problem.
If this is what's happening you can do two things - richen the needle slightly on the ground or add more oil to the fuel.
I'd suggest using a tacho on the ground, then when you find a setting that you like keep a note of it and a quick check on the first flight of the day will save many wasted flights
IRL-1638
Offline Jim Oliver
Re: .. Goes rich...
« Reply #2 on: August 27, 2007, 07:11:29 AM »
"----will save many wasted flights".  And maybe prevent "toasting" an engine. H^^
Jim
Jim Oliver
AMA 18475
steven yampolsky
Re: .. Goes rich...
« Reply #3 on: August 27, 2007, 07:20:34 AM »
Is this muffled SE or wrap-around header and pipe?
How close is the tank to the motor?
Offline Bootlegger
Re: .. Goes rich...
« Reply #4 on: August 27, 2007, 09:51:22 AM »
 Guy's,  I don't think that it is overheating as I have run this engine many times in the past without this problem.
 I am running a side exhaust tongue muffler, plus when flying I bring it back to the takeoff point and the engine still has plenty compression I re fuel and re start right away and make another flight. It re starts easily needles well and again about half way through it goes richer again.
 I'm thinking that if I had a leak in tubing anywhere it would go lean.  I was getting rust in the filter on the other tank so I installed a new one.
 I was having the rich syndrom with the other tank as well.
  As for the tach settings it is running between 10 Thou and 10,300 each start. I am gonna change plugs and stay with T'bolt long w/idle bar as that is what I've been using for some time in all my engines.
  I sure do thank ya'll for your suggestions, and hopefully we'll get it ironed out.
 As for the tank behind the engine it is about 1/2" from the back plate, and when I turn it up it doesn't go hard lean and comes right back when it's level, so that also tell's me that it isn't over heating ??? H^^
Gil Causey
AMA# 6964
