Engine basics => Engine set up tips => Topic started by: Joe Messinger on December 07, 2006, 04:47:39 AM
Hello,
Anyone have any experience with GMS Engines? I see them offered in Tower's catalog. None are available in a C/L version but I wondered if a conversion would be worthwhile. The engines are inexpensive ($59.99) for a .40 and are pretty light. All have ball bearing supported crankshafts.
Joe
Hey, Joe - buy one and bring it to John's during Christmas vacation.
Send me the dimensions for a venturi and I'll make one - we can grab a plane and try it out.
they make a 32 and 36 on a smaller case. One of our guys has the 32. It was a super engine from the first flip. Always easy starting, plenty of power, at least on a speed limit combat plane. The 36 would be a better bet for stunt, although the 32 runs fine. Check the weight on the 40 before you get one. If it is a 40 built on a 46 case it will be heavier than need be. The smaller engines are built more along the lines of a 25 sized case.
I have .25 on a Skyray 35,docile enough for me but capable of most stunts in more experienced hands. All I did was to lock the carb open for now. I wouldn't hesitate to buy another one.
