Good question, despite it seems to be bagatelle.
I think everything depends on the glowplug washer. Many original factory washers are problematic. It must not be too thin (less than 1/32"), too thick (more than 1/16"), too soft (pure aluminum), too hard (Dural, brass, iron, steel). Let me not explain, why.
My bet is to make / order some dozen of pure red copper* washers 1/24" thick, with precise 1/4" inner dia. and not less than 3/8" dia. outside.
This is not a task to machine it with the most primitive lathe.
Tighten it with a 4" "T" key, bravely. (Cannot estimate, how many lb. fts)
Istvan
*where to find red copper rod: bigger soldering iron's spare "iron" used to be made of red copper
