  • June 20, 2025, 02:20:20 PM
Author Topic: Glow plug thread  (Read 1364 times)
Offline Jim Thomerson
Glow plug thread
« on: July 27, 2012, 06:39:46 PM »
In Eric Henderson's engine column in the August 2012 Model Aviation, he makes a correction to his June 2012 column to say that modern glow plug threads are 1/4 x 28 rather than 1/4 x 32.  I have emailed him and asked which plugs and engines use the 1/4 x 28 thread.   I don't have either real modern engines or glow plugs, but all mine are 1/4 x 32. ???
Offline dennis lipsett
Re: Glow plug thread
« Reply #1 on: July 27, 2012, 06:48:48 PM »
That is news to me. Probably to everyone else in the hobby also. I Seriously doubt the truth of that statement.
Dennis
« Reply #2 on: July 27, 2012, 07:09:48 PM »
LOL
« Reply #3 on: July 27, 2012, 07:21:27 PM »
You mean I spent all that extra money on a 1/4-32 tap when a plain old 1/4-28 would have worked?
Wait a minute -- how come my glow plugs fit the 1/4-32 holes I've made?
« Reply #4 on: July 28, 2012, 10:42:58 AM »
   Saw that, but it's clearly not accurate. I have an Arden glow plug from about 1949 (not originally mine, of course!) and it meshes perfectly with a recent-issue Thunderbolt 4-cycle plug and fits any of my engines just fine. Take a glow plug and try to screw it into a 1/4-28 nut, it will to a little bit in and jam.
« Reply #5 on: July 28, 2012, 11:27:03 AM »
Got a reply from Eric apologizing for being confused.  1/4 x 32 it is for standard plugs.
Offline L0U CRANE
« Reply #6 on: July 28, 2012, 12:33:28 PM »
...And, 1/4-28 is our usual 1/4" shaft propnut thread... Metrics are their own thing, though...
\BEST\LOU
« Reply #7 on: July 31, 2012, 04:28:15 PM »
While we're on the subject of glowplugs, I'd like to hear the explaination of why we now have medium reach glowplugs, instead of, or in addition to, shorts and longs. Not sure that the correct answer would come from an ARF/Park Flyer magazine, but I must admit that there is some fresh emphasis on actual building, which is an encouraging sign.  y1 Steve
« Reply #8 on: July 31, 2012, 06:34:31 PM »
While we're on the subject of glowplugs, I'd like to hear the explanation of why we now have medium reach glowplugs, instead of, or in addition to, shorts and longs. Not sure that the correct answer would come from an ARF/Park Flyer magazine, but I must admit that there is some fresh emphasis on actual building, which is an encouraging sign.  y1 Steve
[/quote
Steve,
I think it's because of the head design of some engines. The long actually extends about 1/2 thread into the combustion chamber and the medium ends at the end of the threads. That said there seems to be a distinct difference in running some of these engines with a long vs medium plug with the long seeming to advance the timing a little bit more then necessary. I keep a couple in the flight box and have on occasion used it to get the run that I wanted.
Dennis
« Reply #9 on: July 31, 2012, 09:25:28 PM »
Hi Steve
The the ENYA plugs have always been a medium reach, longer than short, shorter than long.....
Offline Brian Hampton
« Reply #10 on: July 31, 2012, 11:03:48 PM »
AFAIK the only medium length plugs are the Enya and OS but why both Japanese manufacturers went with this is open to question. What I do know though is that an OS plug in an OS 40VF (at least) isn't long enough to get the plug flush with the combustion chamber but an OS/Enya plug is perfect in my Enya 61CXLRS. I must admit I haven't checked my other OS or Enyas though to see how well their plugs fit.
The new OS BE (bio ethanol) engines use an 8mm glow plug thread because apparently a normal plug won't work properly with that fuel.
