Ken, when a new plane takes a lot of laps of burping before shutdown, the standard fix is to tilt the back of the tank outward, OR move the LO's forward. In the case of no warning at all, the reverse should also work. The question then is, are your LO's in the right place? It might indicate that they're too far forward...which isn't terribly likely, but you might also reverse the tilt of the tank by 1/16" > 1/8" at the front. Should work, it says right here in the fine print.
If you were using a metal uniflow tank, you can increase the distance between the uniflow outlet and the fuel pickup. That is another way to go, and would also allow you to use the shutoff loop trickery. If you stick with a clunk tank, you will NOT be able to use a "shutoff loop".
I do have some suspicions about the effects of small vs. large clunks, or tapered clunks. And those sintered bronze filter clunks...I don't see how those could possibly feed constant up to the last drop, since they would be pulling fumes from the inboard side and liquid from the outboard side. So the clunk type might be a useful adjustment, but I've not done that. Maybe somebody else has?
