The hole in the piston must be at 180 degrees w/r to the exhaust ports otherwise the engine does not suck the fuel at all.
Configuration tested today using 10% Omega fuel with no extra castor added and 11.5 x7 wooden two blade prop.
RPM = 7900 - 8200, time of flight = ~ 8 minutes using the 6 fl. oz. Sullivan plastic tank.
Issue is solved and closed.
Matt
