  • June 18, 2025, 05:08:06 AM
Author Topic: Big end rod clearance  (Read 762 times)
Offline Matt Brown
« on: April 23, 2020, 07:08:46 PM »
After replacing bearings and ring in an old ST60, I took it out yesterday to break it in a bit. It fired right up but seized about 30 seconds in. It was plenty rich so I must not have gotten it clean enough. The crank pin is in excellent shape but the rod is tight on it. I thought I’d take it to work where I have a nice Sunnen hone. I figured I’d hone out a touch. Just need to know how much clearance there should be. If it doesn’t work, I’ll try to find a new rod. This is free to try at this point though!
Thanks, Matt
Online Lauri Malila
Re: Big end rod clearance
« Reply #1 on: April 24, 2020, 12:56:56 AM »
Big end 0,03...0,035mm, small end 0,045...0,05mm. L
« Last Edit: April 24, 2020, 10:33:14 AM by Lauri Malila »
Offline Matt Brown
« Reply #2 on: April 24, 2020, 02:08:25 PM »
I would polish the crank pin anyway. A few seconds with a worn piece of 800 paper will do. Just hone the rod until it moves freely on the pin and it will be ok. I use hot soapy water and a tooth brush to clean parts and pre oil all the parts with 3in1 oil or similar. Have you set ball bearings before? If there's a bind it will stress the rod. Is there any castor in the fuel?
Motorman 8)
I used a strip of diamond paper to lightly polish the crank pin. Did not measurably change the pin size. Fuel is Ritchs Brew 22% 11/11 mix. Hone was a bit more aggressive than I wanted. I ended up with just under .002” clearance or .05mm for the metric crowd. That’s the top limit of what Lauri Malila specified. It’s looser than what I wanted. I’ll try to get it on the test stand this weekend and see what I think.
Thanks, Matt
