Hi Jim,
On the first couple of LA 46s I replaced the plastic backplate with FP ones, Before they got difficult to find! I cut my own gaskets, but I will use The RSM ones in future, not worth cutting them at Eric's prices.
My later LA 46s are still being run with the plastic backplates and RTV silicone, plus some loctite on the screws. They have been used an awful lot, both by myself and people that I have lent them to (yes, I must be an idiot to do that!). I have never had a problem. I have a nagging suspicion that people either tighten them too little and they come loose because of vibration, or they really do overtighten them and deform the plastic causing leaks.
RTV and loctite plus the correct torque on the screws seems to be a bullet proof solution, or is it?
Andrew.
