  • June 13, 2025, 05:34:43 AM
Author Topic: McCoy .35 RH crankshaft-case bearing clearence fit?????  (Read 1847 times)
Offline frank mccune
« on: February 23, 2019, 02:39:44 PM »
      Hello All:
      How tight should the above fit be? I am attempting to fit  a"new" crankshaft to this engine but it will not enter the case with ease after polishing with 1200 paper.  I do have a bit or fine lapping grit that I may use but what I need to know is how freely must the crankshaft spin in the case to be proper.
        Tia,
        Frank McCune
Re: McCoy .35 RH crankshaft-case bearing clearence fit?????
« Reply #1 on: February 23, 2019, 03:01:00 PM »
   Make sure that there is no burr or "mushroom" on the end of the crank shaft first.  Measure the old shaft. If it's clean. measure the new shaft and  the bushing to see what you have. Given the nature of McCoy quality control, I'm surprised that it doesn't fit. Try the new shaft in another engine if you have one. Some fine lapping compound, or gentle reaming may be in order, but I'm still curious as to what things measure out at.
« Reply #2 on: February 23, 2019, 04:40:52 PM »
You will also need to check the bushing in the case  for a  ding or ring around the edge, Easy way to check if this is a problem is put the crank in the front to check the fit, Rear should be the same, If it is  OK then you will need a good bit of lapping to fit, Use at least .002 thou clearance  minimum  to start
« Reply #3 on: February 23, 2019, 06:06:40 PM »
       Hello Dan and Randy:
       Thanks for the prompt and informative replies.
        I measured the two shafts and found that they are different in diameter.  When measured on the end where the threads begin the new one measured .4380" and right in front of the intake port it measured .4381".  The original shaft measured .4375" at both places.  I interpret this to indicate the shaft has a bulge of .0006" in front of the intake port.  I did insert the shafts into the case from both ends to determine where the problem may lie as Randy suggested.
       I guess that the best method to remove the bulge is to place the shaft in a chuck and apply some fine paper and oil.  However, I doubt that I have a chuck that will hold the shaft true enough for this process to be accurate.  Perhaps a light lapping to the case may solve the problem, but I will be using the bulge to lap a "ring" in the crankshaft bearing at the tight spot.  On the other hand, what would the harm be if there is a ring in the bearing?
      What grit of paper would you suggest for this polishing of shaft?  The lapping compound is a powder that is mixed with oil to lap pistons to cylinders.  It works very well.
        Be well friends,
        Frank McCune
« Reply #4 on: February 23, 2019, 09:11:03 PM »
       Where does the .0006 come from?  Is the new shaft .4375 in the rear?
       The problem I see is taht you are going to have to try to take off .003 at least, preferably more, off a steel (and possibly hardened) shaft. That's a little beyond just polishing it lightly with sandpaper. .0006 (or .0001) of "bulge" is moot in comparison. It can be done but will have to be very aggressive.
« Reply #5 on: February 23, 2019, 10:23:06 PM »
        Be well friends,
        Frank McCune
Hi Frank
Tough job, and not really something you should try, You should either ream the bushing out to fit,  .003  to .004 thou larger, or find someone with a tool post grinder on their lathe that can grind the crank, They sell an adjustable reamer, that is not real expensive that you could use to open the case out to fit the crank
« Reply #6 on: February 24, 2019, 12:30:05 PM »
Hi Frank
   And it would definitely have to be a grinder, there's no way that you would be able to get .003 off of it by cutting with regular tool. I wold think that would be bare minimum clearance.
    The reamer sounds like a much better idea, and much easier to control the results than trying to use sandpaper (or as might be tempting, a *file*).
« Reply #7 on: February 24, 2019, 08:24:08 PM »
https://www.amazon.com/4380-11-125mm-Straight-Chucking-Reamer/dp/B07DWJ81C1
Cor, gee wilikers . they want 15 bucks .
Was going to suggest skinflint method , wheras if a drill bit ( metric ) was within a gnats dick of korekt ,
it'd open it out . To far if you didnt get it wright .
As your 4380 = 11.1252 mm , a 11 mm drillbit , if you got out of the right side of bed etc
should get it spot on . Seeing a 7.65 drill threw a OS alumn. intake gave .290 , using a drill press . Which is about what I wanted !
Id use a Tap Handle ( Tap & die type ) on the drill bit . It'd want to feed in easy , or youd be stuffed .
The Reamer would be the decadent option , and presumeably failsafe .
Just thow your .4380 in.  on google search , to find them by the million .
« Reply #8 on: February 24, 2019, 09:16:27 PM »
A good used run in bit would be preferable to new
Offline bob whitney
« Reply #9 on: February 24, 2019, 09:34:36 PM »
I have a .437 crank u are welcome to
rad racer
« Reply #10 on: February 24, 2019, 09:49:39 PM »
Hi Frank
Fixed, but oversize (by about the right amount to get it started)  - https://www.mcmaster.com/3087a36 $30
