  • June 15, 2025, 04:34:22 AM
Author Topic: K&B 4011 for Stunt  (Read 2845 times)
K&B 4011 for Stunt
« on: December 12, 2016, 03:21:08 PM »
I've got allot of K&B 4011 stuff left over from my racing days. I read on stuka that they are a good stunt engine with mods so, might be a fun project to put on a Brodak Lagg 3 Lavochkin 8).
I've got the early version light weight front case and the later crank case with the exhaust lugs. It was real wet nosed so I got a double sealed front bearing and left both seals on. I ran it and it sealed so good even the grease stayed in.
They say to lower the sleeve and modify the porting and head but no specs. I can take a good guess and probably come out ok but, anyone know exactly what to do?
Re: K&B 4011 for Stunt
« Reply #1 on: December 12, 2016, 09:32:05 PM »
Parrently was a article in PAMPA , Stan Powell / Les Mc Donald one .
The ' P ' ( stamped 0 head is the FAI Pylon One, straight Fuel / No Nitro . Blew about 8 plugs with mine.
a Gasket may be the answer .  LL~ Chambers same as 21/40 ST , squish band & bowel ( same Dimns. )
Sucks a bit of juice, but not top bad .  sleeve Timings 140/120 odd stock .
Power comes off n on , down & up , even with a perry pump backplate , for rough air fuel feed .  S?P
Theres a few other threads here on them , but nothing definative - untill someone posts the Stan Powell Article HERE . PLEASE .  ;D
He won the World Champs with it , once or twice. So it cant be complettely useless .  S?P
Offline David Zwolak
« Reply #2 on: December 13, 2016, 09:20:34 AM »
I run the engine with good results.  The "P" inscribed heads (on front) are from the pattern version of the K&B 40.  The P head has a hemispherical combustion chamber.  They can be found on original K&B 40 R/C pattern engines, or with luck, in the spare parts bin.  Details on my successful K&B 4011 engine (converted from R/C) are:
-The P Hemi head.
-Retrofit 0.280 venturi with a K&B or ST NVA.
-Extra head gasket (0.010").
-APC 10.5x4.5 prop.
-Fuel 5 to 10% nitro with 20-25% oil (50/50 syn/castor)
-Tongue muffler adapted to engine.
Engine will run in a "wet 2-cycle style" real nicely with a slight increase in RPM in the right places.  The APC prop really works well on this engine - recommended!  One caution from my experience...  The crankshaft on the small front end 4011 version tends to be delicate.  A hit to the ground can bend the crankshaft itself (not just the prop bolt stud).  So word to the wise, don't crash!
Cheers
DZ
« Reply #3 on: December 13, 2016, 10:27:32 AM »
Thanks for the specs, I'll check my head for letters. I have to find or make a light weight muffler. What are the size and number of holes in your tongue muffler?
« Reply #4 on: December 14, 2016, 08:20:57 AM »
I will need to check on the number/size of the tongue muffler holes.  It may take a couple days.
The tongue muffler wasn't anything special.  Just local made by a machinist/modeller, and supposedly for the Double Star 54.  The tongue muffler just happened to also fit my K&B 40.  A convenient match, so I bought the muffler for the K&B.  I ran it as purchased.  If you have access to either of the mufflers supplied with the old DS 54 (there were two of them I understand - a tongue and a tube style), then you could have a ready-made piece with no work on your part.
Check all this out before committing major $, of course.  I am going from memory on the mufflers for the old DS 54.  I could be wrong on the recollection.  I just know that my local purchase tongue muffler runs fine on the K&B 40.  There was no special magic with it.
The key factors with this engine, in my opinion, are the P Head and the APC 10.5x4.5 prop.  The APC prop really allowed the K&B to give an acceptable run for me.  Other sizes/brands did not perform as well, at least the ones I tried.  The APC 10.5x4.5 prop seems to also have a very good reputation among my friends for many .35 to .40 motors, and has worked for me.  That's my $0.02.  Hope it helps as a start point.  Experiment to see what works best for you.
Cheers
DZ
